2002 BMW 5 series issues
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74515
Printed Date: May 15, 2026 at 6:47 PM
Topic: 2002 BMW 5 series issues
Posted By: jaurora
Subject: 2002 BMW 5 series issues
Date Posted: March 15, 2006 at 8:53 AM
My friends BMW has an all factory system. He bought the car used  and in the trunk I found a power wire RCA's and a Ground, meaning the previous owner had an amp hooked up. The problem is some of the speakers cut in and out if bumps are hit. I am guessing that this issue most likely be in back of the factory head unit . How do I remove the factory head unit on this car to look behind it? Also any other suggestions would be more than helpfull as to what this issue could be caused from.
Thank you
MECP certified (If it really means anything)
Jeremy
Posted By: audiophd
Date Posted: March 15, 2006 at 2:56 PM
on bmw's you will need european keys. sound like when they tapped into the wires for the LOC that theres a loose connection. i guess MECP certified doesnt mean anything?
Posted By: tcss
Date Posted: March 15, 2006 at 3:54 PM
Actually no. This is a difficult radio to remove if you don't know what you are doing. Remove the wood trim around the top and sides of the radio, it prys off. Pull the volume knob off the radio. Behind it you will find a T-10 torx screw. Loosen it all the way and the radio will slide out. If the wiring looks good, the factory amp is behind the right rear wheel well. That is most likely where they tapped into the wires. I'm NOT MECP certified, go figure!
There is no such thing as free installation!
Posted By: jaurora
Date Posted: March 16, 2006 at 6:38 AM
MECP means nothing. I am not so much into the audio, remote starts/alarms are my specialty. Now if you need to know whats going on there I can help. Thanks for the info Tcss. I will look into it. Oh yea I do not see anything about european keys need to remove the radio
Jeremy
Posted By: tcss
Date Posted: March 16, 2006 at 3:25 PM
Factory amp behind left rear wheel well. Good luck Jeremy.
Posted By: jaurora
Date Posted: March 17, 2006 at 7:03 AM
I will let you know the outcome. May not be fo another week or so as these remote starters have me swamped
Thanks again
Jeremy
Posted By: auex
Date Posted: March 17, 2006 at 7:20 PM
Definately check the amp first, there could be a bare wire shorting out there.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
