2005 mustang factory subs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74603
Printed Date: April 05, 2026 at 10:44 PM
Topic: 2005 mustang factory subs
Posted By: 05gt
Subject: 2005 mustang factory subs
Date Posted: March 16, 2006 at 6:59 PM
I put in a aftermarket amp to connect these subs to, and at the amp I have 1 ohm is there a way I can wire to have 2 ohms at the amp
the subs are 1.2 ohm per voice coil, they are dual voice coil subs
the way I have them wired is on one sub I went (+) to (+) to amp and then (-) to (-) to amp
how can I make it 2ohm load at the amp
Posted By: arrow12
Date Posted: March 16, 2006 at 9:44 PM
I am pretty sure you can't get a 2 ohm load with thse subs.  About a 1 or 4 ohm load is about it I think.
That's my opinion. Take it, leave it, or correct me.
Posted By: 05gt
Date Posted: March 16, 2006 at 9:57 PM
I got about a 2.4 ohm load out of it
Posted By: arrow12
Date Posted: March 16, 2006 at 10:00 PM
How many subs do you have?  I think I am a little confused on that.
Posted By: 05gt
Date Posted: March 17, 2006 at 12:12 AM
There are two factory subs in this car, one in each door, and they are both 1.2ohm dual voice coil
Posted By: stevdart
Date Posted: March 17, 2006 at 6:19 PM
05gt]t wrote:
e way I have them wired is on one sub I went (+) to (+) to amp and then (-) to (-) to amp...I got about a 2.4 ohm load out of it
The wiring you described is parallel, so you wired the coils together in parallel.  If you measured the result with the speaker unhooked from the amp, and your meter was adjusted for its own internal resistance, then you measured the DCR of the combined coils correctly.  Meaning, if that is the case, then each of the coils is a 6 ohm impedance coil.
The impedance is higher than the DCR reading you get with a meter.  And the reading would be in error if the sub was connected to a power source.  And...with a parallel connection you know that each coil is of a higher value than your combined reading, not a lower value.
6 ohm paralleled with 6 ohms = 3 ohms, and we are talking about impedance, not DCR.  If you measure a 3 ohm load with a meter you should read about 2.4 ohms (impedance / 1.25 = DCR).
Here are your wiring options.  You can buy a more powerful amp and run these at 6 ohms, or take a gamble on overheating the amp with a 1.5 ohm load.  And be sure you know what the power rating for those subs is.  How much factory power did these subs get?
