02 trailblazer w/bose
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74696
Printed Date: April 06, 2026 at 7:10 PM
Topic: 02 trailblazer w/bose
Posted By: mutt69
Subject: 02 trailblazer w/bose
Date Posted: March 18, 2006 at 4:20 PM
Hi i got a 02trailblazer ext W/bose an onstar.I ran the ign wire and pulled the amp . all work exept dash lights any ideals would be great.thanks in advance
Live loud and fast or die slow and silent.        Noize Pollution C.C
Posted By: Fastlearner
Date Posted: March 19, 2006 at 12:55 AM
What do you need advice on. You really didn't state anything.
Posted By: mutt69
Date Posted: March 19, 2006 at 2:49 PM
sorry for bing vague i wanted to know if the foactory bose amp was some how wired into the dash lights.or if someone could point me toward a wiring diagram of the bose system
Date Posted: March 19, 2006 at 8:48 PM
I don't believe the amp is wired with the light circuit however the radio is. Did you change your deck. Check the fuses both inside and outside the vehicle.
Posted By: mutt69
Date Posted: March 20, 2006 at 5:03 AM
ya put a clarion touch screen dvd in . thanks for the in put .should have opted for the relocation harnass .i guess we learn from our mistakes
Posted By: kgerry
Date Posted: March 20, 2006 at 9:36 AM
check your fuses, you may have shorted something during the install... if the same fuse blows again pull the Clarion and look for a wire touching metal behind it or double check to make sure you dont have the illumination wire mistaken for a speaker wire.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
