1991 Toronado Radio
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74973
Printed Date: May 16, 2026 at 5:19 PM
Topic: 1991 Toronado Radio
Posted By: damageinc97
Subject: 1991 Toronado Radio
Date Posted: March 23, 2006 at 1:15 PM
I have a 1991 Olds Toronado withe the touch screen radio/heater combo, and I would like to install an aftermarket CD player in th factory Cassette player under the radio. I have no problem making the trim rings and stuff, but I need to know the factory wiring colors for speakers and such, any ideas? Anybody ever do this? Thanks guys
Posted By: hawn13
Date Posted: March 23, 2006 at 4:47 PM
haven't done one in a while but if I remember right the tuner box is in the trunkon the passenger side on the seat or rear deck it has gm plug on it the metra 70-1858 will plug right into it and it also has the ant right there too like the old gm pickups hope this helps
Date Posted: March 24, 2006 at 8:44 AM
Thanks, I'll look into that tonite, I never thought of it being like the Chevyy truck. Thanks
Posted By: sparkie
Date Posted: March 25, 2006 at 8:23 AM
If you have the BOSE system option you can't simply add a new headunit. You either need to buy a interface to allow it, or scrap everything in the factory system, speakers and amps, and replace everything. The BOSE system uses a digital amp and speakers ranging from 1/4 ohm to 2 ohm usually. These will destroy your new radio. Your may want to consider the option of adding a FM modulated CD changer. They don't sound as good, but in your case will be easier to install.
------------- sparky
Posted By: kgerry
Date Posted: March 27, 2006 at 9:07 PM
actually you can still use the 70-1858 if you use a PIE differential converter inline... i have used them on Bose systems many times....
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Date Posted: March 28, 2006 at 9:37 AM
It doesnt have the Bose system, I already changed the front and rear speakers with regular aftermarket. Im going to dig into the back today or tomorrow to check on that 70-1858, I bet its there. I wasnt sure about messing with it because of the touch screen, but i bet its not that bad, just time consuming. Thanks guys
