sound stage, imaging in 2 seater
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=75159
Printed Date: April 04, 2026 at 5:15 PM
Topic: sound stage, imaging in 2 seater
Posted By: shines
Subject: sound stage, imaging in 2 seater
Date Posted: March 26, 2006 at 11:15 PM
(premise) I have a small honda crx without the mounts to install rear speakers, and with my roll bar it is impossible to mount spkrs in that area.
(goals) clean clean balanced sound to play multiple genres of music... i listen to a lot of brassy symphonic band music, and really want the instruments to come alive.
1) my install will have to consist of only speakers in the front and maybe a sub in the hatch area.
2) i do not want to use my stock speaker locations; i would rather customized my door inserts so that my front speakers will be closer to on-axis.
3) is quality sound in this limited amount of space impossible, or is it as easy as installing quality mids, tweeters, a tasteful sub, and an amp???
4)last, i'm not using a head unit, but a carputer to run everything (this is in the planning stages,)how will this effect sound quality.
thanks
1991 HONDA CRX
EMPTY
Posted By: Steven Kephart
Date Posted: March 27, 2006 at 12:03 AM
2)  Speakers are more like light bulbs than lasers.  They don't project their sound directly forward.  In fact they only start to beam at upper frequencies, that frequency being determined by the cone size of the driver.  Try reading my "Advanced front Speakers" thread above for more information, mainly what I write on page 2.
3)  That depends on your definition of "quality".  I've found that peoples definition of this is greatly effected by their experiences.  If you have experienced a really good sounding system, then that is your reference point to use on your own system.  Working on your experiences and knowledge will greatly help you in building your own system.  This is a very time consuming, but will be worth it in the end.
Posted By: shines
Date Posted: March 27, 2006 at 10:31 AM
I reread your advanced front spkrs thread, and understand the lightbulb analogy. How will only having speakers in the front of my car effect the sound quality.
I was thinking about using the mids that you suggested in your adv front spkrs thread, and added some tweeter and a 10 inch sub. I'll reread your posts again for more ideas.
1991 HONDA CRX
EMPTY
Posted By: DYohn
Date Posted: March 27, 2006 at 10:44 AM
shines wrote:
I reread your advanced front spkrs thread, and understand the lightbulb analogy. How will only having speakers in the front of my car effect the sound quality. .
Speakers only in the front is prefered by many people, like me.  The front sound stage is all that really matters.
Date Posted: March 27, 2006 at 1:04 PM
I have to agree with Dyohn there.  The lightbulb analogy was having to do with your comments about aiming.  It may not be worth the effort.  That will depend on speaker selection and crossover points.
Posted By: arrow12
Date Posted: March 27, 2006 at 3:16 PM
I think this relates to the orginial topic...  Why is the front sound stage the only "important" part?  I couldn't figure out how to explain that to someone.
That's my opinion. Take it, leave it, or correct me.
Posted By: DYohn
Date Posted: March 27, 2006 at 3:27 PM
The very basic reason is sound is supposed to come from in front of you.  Your ears face forward.  When you listen to a live performance (concert) you generally face the stage for the best sound.  The ideal way to listen to recorded sound is to face the source.  So in a car, you want the sound to appear as if it's coming from in front of you.  Since that's where the windshield lives, you have to compromise of course.  posted_image  You do not want the sound to come from behind your head as this is not natural.
Posted By: shines
Date Posted: March 27, 2006 at 6:50 PM
I've just made up my mind that I don't want a woofer (no space.)
Here's what I have on the sketch board:
- 2 extremis 6.8's in the stock location (will have to be modded)
- 2 av5's-- not sure on location-- maybe molded into the same location as the extremis 6.8's??
- a 4 channel amp
- and the grace of GOD to make this sound good without a head unit-- I'm using a dedicated computer as my media player..
Give me your thoughts; I appreciate your knowledge.
1991 HONDA CRX
EMPTY
Posted By: DYohn
Date Posted: March 27, 2006 at 7:48 PM
What are you using for tweeters?
Posted By: shines
Date Posted: March 27, 2006 at 8:02 PM
I'm not sure; I don't know much about this hobby.you
What would you suggest?
How does my short-list of speakers look so far?
1991 HONDA CRX
EMPTY
Posted By: shines
Date Posted: March 27, 2006 at 8:15 PM
I did a little bit of searching and the seas lotus RT25A/F appears to be popular.....
1991 HONDA CRX
EMPTY
Date Posted: March 27, 2006 at 11:25 PM
The Lotus are a nice driver as well.  In fact, I believe Dyohn runs them in his car stereo.  They has one or two advantages over the Extremis, but in my admitidly biased but still honest opinion, the Extremis has many more advantages.
Posted By: shines
Date Posted: March 27, 2006 at 11:32 PM
I was going to use the seas lotus rt25f as my tweeter; the extremis as my mid bass; maybe the adire AV5's--I'm not sure if they fit in with the listed components; no sub.
1991 HONDA CRX
EMPTY
Date Posted: March 27, 2006 at 11:41 PM
- a 4 channel amp
IIRC the AV5's are no longer available.  However a quick e-mail to Adire should clear that up.  But then, I would recommend simplifying the process and just run the Extremis up to the tweeters.  They have a nice response all the way up to 5 kHz without much issue.
Here's a good tweeter: https://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=264-735  And here's it spec sheet: https://www.partsexpress.com/pdf/264-716s.pdf  It has very good extention on both ends as you can see by it's response.  I like that their measurements are at 94 dB.  Also if you notice on the waterfall plot, there aren't any bad stored energy ridges.
Date Posted: March 27, 2006 at 11:51 PM
Doh, my bad.  I should have looked up your model number.  Unfortunately I can't find any measurements on those speakers.
Posted By: shines
Date Posted: March 28, 2006 at 12:44 AM
Steve, thanks for all the help.
I'm going to go with the neo3's that you suggested, the extremis 6.8's and call it a rap. Hopefully this sounds great.
--But then, I would recommend simplifying the process and just run the Extremis up to the tweeters.--
what exactly do you mean by "run the extremis up to the tweeters?"
1991 HONDA CRX
EMPTY
Date Posted: March 28, 2006 at 2:31 AM
The Extremis is a wide band driver capable of delivering great midrange performance.  You really don't need to add a seperate midrange to the equation as this will make things more complex with crossover design.
That does bring up the next question; what are you going to do about the crossover?  Keep in mind that the crossover is THE most important part of any speaker system and will determine how good your final results are.
Posted By: shines
Date Posted: March 28, 2006 at 2:33 PM
i swear your sound domain page is a dangerous place: it makes me want to put a sub into the mix. i really like the way you installed your sub.
Crossovers: i've been reading through old post here, and the bcae, but i haven't found a solution.
1991 HONDA CRX
EMPTY
Date Posted: March 28, 2006 at 2:49 PM
1) Thanks!  I don't recommend that to people as there was a lot of work involved.  Hopefully some day I will finally finish it though. posted_image
2)  Well then you are going to have to ask yourself how much difficulty you are ready to face.  Read the different levels of speaker designs I list in that above sticky and decide which one you want to take on.  However if they all look too difficult for you, then I would suggest a  pre-available speaker set from one of the many manufacturers.
Posted By: shines
Date Posted: March 28, 2006 at 3:42 PM
I definitely want to venture somewhere in the "better" category, but without getting too technical.
Can crossover success be as simple as using inline filters.
how hard is it to create my own crossovers from coils and capacitors? is it as easy as buying the right parts and throwing it together???
diy for life- i really like the way you installed your subposted_image
1991 HONDA CRX
EMPTY
Date Posted: March 28, 2006 at 4:12 PM
A passive crossover is an inline filter.  But it isn't as simple as selecting some parts and throwing them together hoping to get decent results.  Even using textbook alignments won't provide you with very ideal results.  This is because the response of the drivers in their intended locations must be taken into account.
I was involved in quite a few crossover designs when I worked at Adire.  My boss, Dan would have me build a test enclosure and have me mount the speakers.  He would then take his computer and hardware (the expensive equipment I mention in the other thread), hook it all up to each speaker and measure their individual responses.  He would then use his computer program to design a crossover with those response curves, and try to get the best response with the fewest components.  Then he would hook up his computer again to the speakers and listen to his designed crossover.  After he is happy, he would order the parts, I would build the crossover and we would listen to the final result.
Posted By: DYohn
Date Posted: March 28, 2006 at 5:22 PM
Hi there.  Yes, I used to use the Seas RT25A tweeters in my car as they are part of the Lotus Reference set.  These now live in my wife's car and I'm using a set of Eclipse comps (with Vifa drivers) in my new car.  The Seas tweeter should work well with the Extremis in a 2-way setup as it can be crossed over as low as 1700Hz since it has a low fs.  It is a great sounding tweeter (and the Extremis is a great sounding woofer!)  And I agree you really don't need a 3-way set unless you really want to try that.
Steven's comments about crossover design is right on, of course.  A text-book crossover might provide a starting point and in some cases turns out to work fine.  But for example, the Seas tweeter mentioned above has 89.5db sensitivity and the Extremis is 86db, so in addition to a simple crossover network you'll need to pad the tweeter by at least 3db.  If you have the interest and the time to tweak and get it right, crossover design is the most fun part of speaker building IMO.
Posted By: shines
Date Posted: March 28, 2006 at 5:32 PM
Having never taken the easy way out on anything; I will stick it out, learn more about this hobby, and feel good.
1991 HONDA CRX
EMPTY
Posted By: shines
Date Posted: March 28, 2006 at 5:45 PM
https://www.crutchfield.com/S-E3bSqe7T4fh/cgi-bin/ProdView.asp?g=82600&I=20603KX3
active crossovers?
I'm not sure that the one in the above link is appropriate for my application, but active x-overs appear to be an easier solution.
1991 HONDA CRX
EMPTY
Posted By: DYohn
Date Posted: March 28, 2006 at 6:21 PM
Sure, active is a good way to go.  If you do this you'll need a 4-channel amp for your front stage: 2 channels for the woofers and two channels for the tweeters.  Active crossovers can allow "tweaking" to get the sound balanced properly, plus when done proerly they can increase the SQ and efficiency of a system.  The down side is additional amplifier channels required and increased system complexity and more difficult setup, as well as noise that can be introduced by the crossover.  If it was me, I would not use the particular one in your link.  I'd look at something from Audio Control or a similar company.
Date Posted: March 28, 2006 at 7:00 PM
You will also probably want an equalizer as well.  Try looking for a processor that includes both to simplify things.  Or you could go to a nice digital processor like this one: https://www.altomobile.com/html/ucs_pro.html  This will get you great control over every aspect of the signal, and do it without possibility of adding noise (well, except for maybe from the converters).  However it will take a lot of time and patience to set up properly.
Posted By: shines
Date Posted: March 28, 2006 at 8:07 PM
I really like the alto mobile UCS; it will work well with my carputer. The only problem is that I can't a usa seller.
1991 HONDA CRX
EMPTY
Posted By: stevdart
Date Posted: March 28, 2006 at 9:47 PM
Here are some links to programs I got from others here in the forum (you've been tralking to some of them!).  Speaker Workshop is a passive crossover design program.  The other programs associated with the FRD can be picked through and chosen, and add as you can or you see fit.   At this point in my speaker-building hobby, I'm getting the enclosure down with Unibox, copying the manufacturer's response and impedance curves using SPL Tracer, and designing the crossover with Speaker Workshop.  The rest of it...I use intuition and whatever knowledge I've gained from all sources.
For a bunch of calculators you can refer to often, as I certainly do, this is where you want to go.  And Rod Elliott has interesting and useful things to say here.
Date Posted: March 29, 2006 at 2:23 AM
Hey Steve, one thing I recommend is getting at the very least a cheap RTA software program and mic to meter the speakers rather than using the manufacturers response curves.  The reason for this is those curves are taken anechoic on an IEC baffel, and usually are smoothed quite a bit.  Also the response curve of the mid might not be taken at the same output level as the tweeter which could effect the results even more.
Posted By: shines
Date Posted: March 29, 2006 at 7:51 AM
guys,
thanks for all the help. i feel like everything is finally coming together. would this 'system' be more complete with a sub; i want an excuse to copy how steven installed his sub, and a reason to create a new console.
1991 HONDA CRX
EMPTY
Date Posted: March 29, 2006 at 12:49 PM
It would definitely benifit from a subwoofer as the Extremis can't quite cover the whole bottom octaves on it's own.
Posted By: shines
Date Posted: March 29, 2006 at 8:17 PM
posted_image
I would love to install my speakers like that....
1991 HONDA CRX
EMPTY
Posted By: shines
Date Posted: March 29, 2006 at 8:42 PM
I think I want to modify the above layout; I would rather it be a 2 1/2 way system with a second mid-woofer crossed over to produce bass: frequencies below 200hz, while the first mid-woofer will handle all of the mid-range. I believe this will better fit my space.
1991 HONDA CRX
EMPTY
Posted By: shines
Date Posted: March 30, 2006 at 9:07 PM
So what do you guys think about center-mounted speakers
1991 HONDA CRX
EMPTY
Posted By: DYohn
Date Posted: April 02, 2006 at 7:23 PM
For what?  They make great center channels...
Posted By: stevdart
Date Posted: April 02, 2006 at 9:05 PM
Somehow I missed this post, Steven.  I'm eventually going to get to that level, but I have to take widdle baby steps to get there.  I just have to experience a catastrophic failure doing it this way first.  (...or it could be that my ears are very forgiving!)
Date Posted: April 02, 2006 at 9:15 PM
You should be able to do it for pretty cheap.  And even if your measurements aren't very accurate due to sound car, microphone, etc. issues, it still will be more accurate than using the manufacturers curves.  Here's a link to some software: https://www.trueaudio.com/  Note that I have not used this software before, I just know it is available for cheap.   And here's a microphone: https://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=248-625
