no dash lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=75307
Printed Date: May 05, 2026 at 11:57 PM
Topic: no dash lights
Posted By: wb0720pb
Subject: no dash lights
Date Posted: March 29, 2006 at 11:56 AM
I installed an after market sony cd player in a 97 Pontiac grand am Gt  that already had the wiring cut.  I installed it with some difficulty and it now works fine except that the dash lights are now inoperative.  All other lights/systems work. The fuses are all ok.  Iinitially had a wire wrong and the parking lights also did not work but I fixed that.  Is there sone fusable link I have blown or wire that I failed to connect?:oops:
Posted By: Benji999
Date Posted: March 29, 2006 at 3:08 PM
you might want check and see if your tail lights come on, if not replace it's fuse and that may fix your problem
Posted By: kgerry
Date Posted: March 29, 2006 at 3:22 PM
you may want to remove the radio and check for a pinched or shorted wire... i suspect you'll still find it's a blown fuse right now, but if you replace it and it blows again right away, remove the HU and try to source the actual cause of the problem....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: wb0720pb
Date Posted: March 29, 2006 at 5:17 PM
The head unit is out, no wires connected, the fuses all are good and still no dash lights.  I think I zapped something.
Posted By: chaos420
Date Posted: March 29, 2006 at 7:29 PM
Look for a shorted out wire in your cars stereo harness, factory stereos use an illumination wire (commonly an orange wire) to supply power to the lights in it.  Aftermarket stereos draw this power directly from the acc wire, so you're left with an unused wire behind your deck.  The illumination wire is tied into the same circuit as your dash lights and usually your tail lights, if it shorts out you could either blow a fuse, or melt your cars wire harness.  This happened to me, the illumination wire grounded itself and the first symptom was no dash lights but eventually fried my ecu.
Posted By: geepherder
Date Posted: March 29, 2006 at 8:38 PM
You could also have fried the dimmer switch when you first hooked it all up.
Posted By: bryzaa
Date Posted: April 14, 2006 at 10:43 PM
I had this same problem in my 89 cefiro, first everytime I turned the light on the stereo went off, then I fixed that and I had no dash lights or tail lights. In the end i put in a bigger fuse, and had to run a new ground wire. As when the lights were on it was not grounding properly, I checked this with dmm and got it sorted
Bryzaaa
Date Posted: April 15, 2006 at 2:23 PM
You shouldn't replace a factory fuse with one of a higher rating- find the problem and fix that.
