horn & brakelight problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=75344
Printed Date: May 05, 2026 at 10:58 PM
Topic: horn & brakelight problem
Posted By: mattsthru
Subject: horn & brakelight problem
Date Posted: March 29, 2006 at 7:17 PM
Im having a problem with my cars electrical system Im pretty sure its got something to do with my sounds. My horn and brakelight fuse keeps blowing. Not immediately but after several hours. I blew three 20a fuses already. I'm running a 4 gauge power wire that goes right next to the fuse box and follows the tail/brakelight wires all the way to the trunk. Could I just hook up a circut breaker instead of putting a fuse? Or should I go with a slightly bigger fuse?
------------- On a Mission...
Posted By: electrostatic
Date Posted: March 29, 2006 at 7:32 PM
determine what is causing the fuses to blow and fix it. the fuses are there to prevent fires. a little more information and i'm sure someone can help you trouble shoot the excessive current draw situation.
