triple sub box
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=75828
Printed Date: April 03, 2026 at 8:04 PM
Topic: triple sub box
Posted By: ben k
Subject: triple sub box
Date Posted: April 07, 2006 at 4:03 AM
hi i am going to build a triple sub box for my JBL subs should i put all three in one big enclosure or three seperate ones ?? also what size do you think it should be i was thinking 1cubic foot including driver displacement they are 10" gt3 s cheers ben
Posted By: supradude
Date Posted: April 07, 2006 at 4:33 AM
It don't matter, you can do it either way. I prefer going with the one box with dividers in it. Are you going to go ported or sealed? That will determine the air space you need per sub.
------------- '85 Toy
Posted By: ben k
Date Posted: April 07, 2006 at 5:01 AM
sealed all subs and amps are identical and will use a vibe deltabox to boost and split signal 3 ways :)
Posted By: Aruman
Date Posted: April 07, 2006 at 5:22 AM
i'll prefer to put them in one big enclosure but with 3 chamber so that each sub can get it's own airvolume(cuft). if you put them in one big enclosure with no chamber so they share the same airvolume, they will work fine, but if one day one of the drivers fails, chances are that the other drivers can be damage too. i.e. you have 3 10" subs and they require 1 cuft per subs, you put them in one big enclosure with no divider, so they share the airvolume, and if one of the subs doen't work good and fail, then the other 2 will get more airvolume, 3cuft for 2 subs, each subs will have about 1.5cuft and can damage the woofer depend on the brand and the cuft range they need.
------------- Shaking The Neighborhood
Posted By: ben k
Date Posted: April 07, 2006 at 5:30 AM
cheers for that will put them in seperate chambers what about the sound difference between 1 chamber and 3 seperate ones
Posted By: kirktcashalini
Date Posted: April 07, 2006 at 10:49 AM
If working proporly, not anything noticible i believe... other than you need to design the box 1.5" longer because the 2 dividers of 3/4" MDF in there taking up valuble airspace  ------------- 99 Blazer LT. Yellow Top. Big 3. Infinity Kappa Speakers All Around. Jensen CD/DVD flip out. 2 Infinity Kappa Perfect 12DVQs powered by a Alpine PDX600.1 (in one custom box, building a FG box)
Posted By: boardinbum
Date Posted: April 07, 2006 at 11:03 AM
If it's a vented enclosure, you put all three in the same chamber, and one dies, you could have a potential problem. But in this case, if one dies, and you have an extra cubic foot or so for the other two subs to split, it doesn't matter. It won't damage your subs, it will just give them a little more low end response.
Posted By: ben k
Date Posted: April 08, 2006 at 4:03 AM
cheers for that will use seperate ones will be better for fine tuning cheers ben
Date Posted: April 08, 2006 at 10:54 AM
The recommended sealed box is between 0.7-0.8 ft^3 per sub.
