cant understand how 2 cacl req amp power
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=75888
Printed Date: April 03, 2026 at 1:50 PM
Topic: cant understand how 2 cacl req amp power
Posted By: homerb
Subject: cant understand how 2 cacl req amp power
Date Posted: April 08, 2006 at 11:34 AM
hi
i have 2 MA Audio MA100XE 10 " subs rated 300 Watts RMS
if i wire them in combination series & parallel 2 a mono amp how much power do i require from the amp?? is the total power req jus added up (300W+300W=600W RMS) or is there some other calculation??
thanks 4 ur help
:D
Posted By: DYohn
Date Posted: April 08, 2006 at 11:38 AM
You have it right but you must also account for how the subs will present their load to the amplifier.  You can safely use any amp up to 600 watts RMS into the total impedance of the subs.  What is their impedance and how are they wired?
Posted By: homerb
Date Posted: April 08, 2006 at 11:43 AM
theyre 4 ohm DVC and wired in combination series parallel
theyre wired like the 2 4 ohm DVC diagram in the site suggests
Posted By: forbidden
Date Posted: April 08, 2006 at 11:45 AM
If they are wired in a series / parallel circuit, the net load is 4 ohms and a 2 channel amp would be best used. Make that a large 2 channel amp rated somewhere around 150w rms x 2 that bridges to about 600w rms x 1 into 4 ohms. If yuo have the subs wired in a all parallel circuit, then a mono amp that makes 600w rms x 1 at 1 ohm is what you should be after.
Posted By: homerb
Date Posted: April 08, 2006 at 11:50 AM
ok thanks a lot
thts a big help
cheers
posted_image
