no stereo memory
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=75993
Printed Date: May 16, 2026 at 12:13 AM
Topic: no stereo memory
Posted By: neetneet
Subject: no stereo memory
Date Posted: April 10, 2006 at 8:59 AM
i just bought and had my new jvc stereo installed and everytime i set a radio station or set my equalizer  it's erased everytime i turn the car off.can someone   tell me the problem so that i'll know how to fix it?:(
Posted By: supradude
Date Posted: April 10, 2006 at 9:25 AM
It has a memory wire that has to have constant power. You must have it connected to a wire that loses power when you turn off the car.
'85 Toy
Posted By: geepherder
Date Posted: April 10, 2006 at 7:54 PM
Yeah, the yellow wire on the JVC harness should show a constant 12 volts- if it does not, make sure it's connected properly (hopefully you used a harness for your car) and if it is, check the fuses.
Posted By: neetneet
Date Posted: April 10, 2006 at 9:18 PM
thanks for the help,fixed the problem in less than 10 minutes !
