volt meter in monte carlo
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76126
Printed Date: May 16, 2026 at 3:45 AM
Topic: volt meter in monte carlo
Posted By: donvito08
Subject: volt meter in monte carlo
Date Posted: April 12, 2006 at 12:03 PM
i have a 1986 monte carlo ss running an audiobahn a8000t 8000 watt amp with two audiobahn single 4 ohm 12's since adding hte system my volt meter is reading like 14-15 volt in the dash any reason for this and could this cause any problem? i have a cap but have not got around to putting it in.
Date Posted: April 12, 2006 at 12:04 PM
sorry 800* watt amp
Posted By: kirktcashalini
Date Posted: April 12, 2006 at 1:31 PM
and what voltage do you think your system should read? 14.4volts is what it SHOULD be when car is running... 12v is only when the car is off and it is running off battery, not bat+alt.
------------- 99 Blazer LT. Yellow Top. Big 3. Infinity Kappa Speakers All Around. Jensen CD/DVD flip out. 2 Infinity Kappa Perfect 12DVQs powered by a Alpine PDX600.1 (in one custom box, building a FG box)
