03 impala
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76195
Printed Date: April 02, 2026 at 10:03 AM
Topic: 03 impala
Posted By: jesse75042
Subject: 03 impala
Date Posted: April 13, 2006 at 9:18 PM
am try to install aftermarket amp and sub in my car but keeping factory radio. i know ineed to use hi level converter and butr do i install it before factory amp or afterwards. last where do i hook up remote wire in factory system so i wont hook up in fuse box straight on with swicth any help will be good thanks
Posted By: geepherder
Date Posted: April 14, 2006 at 8:50 AM
I remember reading some time ago that in factory amplified Impalas, the bass decreases as you turn up the volume. If this is the case, you need to get your signal before the factory amp. I believe the factory radio already has high level outputs, so yes, you will need to use a line out converter. If you can't find a suitable wire to use as remote turn on, you can always run to the accessory lead at the ignition switch. It should be brown, but test it first.
------------- My ex once told me I have a perfect face for radio.
Date Posted: April 15, 2006 at 2:34 PM
thanks for info will give it a try
