radio removal - Previa
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7645
Printed Date: April 29, 2026 at 7:50 PM
Topic: radio removal - Previa
Posted By: boxerbill
Subject: radio removal - Previa
Date Posted: January 04, 2003 at 1:21 PM
Hello
I am trying to remove the factory radio in my '91 Toyota Previa, with no success. Haynes book says to remove to upper screws in fuse holder area (no problem). It then says to remove four screws to allow removal of the cig lighter/ashtray assembly. Well I can get the screws out but the assembly will not come out. Is there a trick that I am missing? It looks like this assembly must come out to access the other two screws to allow the removal of the center console section that holds the radio. Any help would be greatly appreciated!
Posted By: Velocity Motors
Date Posted: January 04, 2003 at 5:03 PM
https://carstereohelp.com/stereoremovalToyPrevia.htm
Date Posted: January 04, 2003 at 5:41 PM
posted_image
Jeff,
THANKS! I knew there had to be a trick to it. Again... Thanks!
Bill
Date Posted: January 04, 2003 at 6:20 PM
No problemo Bill..... anytime. posted_image
