what kind of amp do i need?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76833
Printed Date: April 07, 2026 at 10:57 AM
Topic: what kind of amp do i need?
Posted By: 187smurf187
Subject: what kind of amp do i need?
Date Posted: April 26, 2006 at 2:11 PM
I LIKE THIS BOX AND IM GOIN TO BUY IT BUT I WANT TO BUY THE AMP THAT CAN PUT IT TO WORK I REALLY WOULD LIKE TO KNOW BEFORE I GO AND SPEND MY MONEY AND BURN OUT MY SUBS AND MESS STUFF UP :) THIS IS THE BOX
FOR BETTER VIEW CLICK ON THE LINK
https://images.bestbuy.com/BestBuy_US/images/products/7683/7683526_ra.jpg
Subwoofer Size=12"
Subwoofer Quantity=Pair
Box Design=Bandpass
Amplified=No
Resistance (Ohms)=4 ohms
Built in Crossover=Yes
Woofer Composition=Injection-molded polypropylene cone
Woofer Surround Foam rubber
Peak Power Handling 1100W
RMS Power Range (watts) 600W
B@zZ SmurF B@zZ
Date Posted: April 26, 2006 at 2:16 PM
sorry about the pic posting as you all can see im new at this LOL
Posted By: xtremej
Date Posted: April 26, 2006 at 2:23 PM
Are those the specs for both subs, or each one?  IF each look for an amp that is rated at 600 watts rms and is stable @ 2ohms. Do you have any amps in mind?
I just noticed you have built in crossover in your specs, is there a crossover in the box?
Date Posted: April 26, 2006 at 2:31 PM
i had this kenwood amp in mind here are the specs for it
  • two-channel car amplifier
  • 170 watts RMS x 2 @ 4 ohms
  • 250 watts x 2 RMS @ 2 ohms
  • 500 watts RMS x 1 bridged output at 4 ohms
  • wired remote control for bass boost and low-pass filter
  • Built-In high pass and low pass filters
  • bass boost (0-18 dB) variable from 40 to 100 Hz
  • Tri-way capable
  • MOS-FET power supply
  • C--E--A-2006 compliant
  • Built-In High Powered cooling fan
  • preamp + speaker-level inputs
  • preamp outputs
  • 13-5/8"W x 2-5/16"H x 11-1/4"D
  • WHAT DO YOU THINK?
    Posted By: xtremej
    Date Posted: April 26, 2006 at 2:36 PM
    From what I am seeing you'll have to run in stereo @ 170x2 @ 4ohms. If your speacs are for both subs ie they are svc w/4ohm voice coils (each) yet they are a combined wattage of 600 rms?
    Posted By: redteam22003
    Date Posted: April 26, 2006 at 3:00 PM
    Do people sale amps on this forum?
    Posted By: xtremej
    Date Posted: April 26, 2006 at 3:08 PM
    There is another forum, private parties can sell equipment. Click on forums and you'll see it.
    Date Posted: April 27, 2006 at 5:59 PM
    alright thanx xtremej its kind of confusing but ill try something
