battery or cap
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76858
Printed Date: April 06, 2026 at 7:10 PM
Topic: battery or cap
Posted By: accessoride
Subject: battery or cap
Date Posted: April 26, 2006 at 7:49 PM
i have  2 12" 4 ohm dvc subs with a 2400 class d amp but the amp alone has 3 40amp fuses in it and is pulling alot of power so i bought a 12v battery from battery warehouse to put in the back but now my installer is saying that the battery is too small and might blow up if ran  in series with my under hood battery. should i just buy a cap and if so how big of a cap? or should i just buy a red cap battery to run in the back
accessorider
Posted By: DYohn
Date Posted: April 26, 2006 at 8:51 PM
You need a high-output alternator.  And no, you do NOT want to run two batteries in series.  In parallel, sure.
Posted By: jeffchilcott
Date Posted: April 27, 2006 at 7:51 AM
The alternator is the only thing that will provide and make the power your amp will demandfrom that point if you are having problems with charge discharge rates, look into a sealed battery like an optima or kinetik.
But Alternator First...Batteries and Caps will not help your problems...Unless your problems are that you dont like your alternators or any electrical item in your car and wish to fry them.....
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
