vented enclosure specs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76861
Printed Date: April 06, 2026 at 5:21 PM
Topic: vented enclosure specs
Posted By: gi jesus
Subject: vented enclosure specs
Date Posted: April 26, 2006 at 9:09 PM
im going to get 2 alpine type-e subs (12") and im looking for some specs on a vented enclosure :)
and also an amp for them
any ideas?
'92 ford ranger
2 swe-1041 alpine 10"s
1 Vented enclosure
1 alpine 9811 HU
1 kenwood kac-8152d
Posted By: stevdart
Date Posted: April 26, 2006 at 9:24 PM
SWE1242 or something else?  Info  Info  Info
Posted By: boardinbum
Date Posted: April 27, 2006 at 1:20 AM
There's a reason Alpine doesn't give recommended vented enclosure specs for that sub.... It's made to be used in a sealed box. I used one in a 1.5 ft^3 sealed box and was pleased with the results.
Posted By: gi jesus
Date Posted: April 27, 2006 at 7:51 AM
im currently running 2 SWE-1042  10"s in a vented enclosure and they hit pretty good, but i can get a good deal on 2  SWE-1242 12" so i was just wondering
also anyone heard anything about or used  alpines PLV-7 or PLT-5 ?
'92 ford ranger
1 Vented enclosure
1 alpine 9811 HU
1 kenwood kac-8152d
Posted By: Kadetheus
Date Posted: May 13, 2006 at 7:17 AM
i personally agree with boardinbum. although you can make a vented box for just about everyspeaker. you would definately need to be careful with alpines. and if you must go vented, please use a subsonic filter!! they are great if you would (i know it sounds old school) make the box slightly larger than asked for or put some good ol' polyfil in the box for deeper bass. but alpines tend to clip easily especially in a vented box once you crank 'em. they are a great speaker on lower powered amps (esp type e) but will buckle under pressure.
Posted By: jayson358
Date Posted: May 13, 2006 at 2:45 PM
i have 2 new type r's in a 1.4 cu ft each ports tuned @ 40hz and inside lined with dynamat and a clif cd10.1lx amp all wired @ 1 ohm and the subsonice set about 23hz and they are the hardest cleanest 12's ive ever heard in a ported box and there's no port noise in the front of the car
93 diamante
pioneer deh-p3800mp
crossfire 40 band eq
alphasonik pma4075 mid amp
clif designs cd10.1Lx sub amp
powerbass xtreme 6 1/2 comp
"   " 6x9 rear
alpine 2 12" type r
ported 40hz tune
Date Posted: May 14, 2006 at 9:09 PM
Thanks for the useless info, jayson.
