double din in a magnum
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76944
Printed Date: April 04, 2026 at 3:51 AM
Topic: double din in a magnum
Posted By: mxxmikexx
Subject: double din in a magnum
Date Posted: April 28, 2006 at 9:51 AM
does anyone have any pics or any links of a double din radio install in a dodge magnum?
Posted By: goodeforu
Date Posted: May 01, 2006 at 11:32 PM
try the metra 99-6510 this should do what you are looking for.
Posted By: forbidden
Date Posted: May 02, 2006 at 1:41 AM
This car uses a single din adaptor kit. You will need to do the cut and and glass / bondo routine to get a double din unit into the dash. I was just on the Dodge forum and someone there had pics of a new Dodge with a double din unit installed. If you can't find it, e-mail me tomorrow, forbidden@telus.net and I will send you the link.
Date Posted: May 03, 2006 at 2:47 PM
the customer went ahead and ordered the dash bezel from the magnum with the factory nav. screen, I'll find out tomorrow how close it will be to fitting a double din.
Posted By: hawn13
Date Posted: May 03, 2006 at 5:33 PM
if he ordered the dodge nav dash piece all you need is 99-6510 no cutting or modifying required to the dash
