blowing a fuse and illumination problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=77018
Printed Date: April 02, 2026 at 6:46 AM
Topic: blowing a fuse and illumination problem
Posted By: acopsy88
Subject: blowing a fuse and illumination problem
Date Posted: April 29, 2006 at 2:23 PM
OK heres the scoop i have a 1997 eclipse spyder. I recently took out my xplod deck i was borrowing from a friend and put in my new eclipse 3404 deck. i made sure all of my wires were fine and i got a proper ground. the first thing i noticed after all the wires were on. My illumination would not turn on my gauges work but no glow out of them. also neither of my dimmer works either. so i of course rewired it and checkedfor any frays or open wires which they were all fine. then i put it back in and my friend said my tail lights were out and i immediately changed the fuse but by thenit blew instantly so after trial and error . i finnaly figured out when my deck was on it would blow a fuse. i have no idea iv checked wires their all good, btw i have 2 jl audio w3s and a memphis 1000d if that helps thanks adam OK heres the scoop i have a 1997 eclipse spyder. I recently took out my xplod deck i was borrowing from a friend and put in my new eclipse 3404 deck. i made sure all of my wires were fine and i got a proper ground. the first thing i noticed after all the wires were on. My illumination would not turn on my gauges work but no glow out of them. also neither of my dimmer works either. so i of course rewired it and checkedfor any frays or open wires which they were all fine. then i put it back in and my friend said my tail lights were out and i immediately changed the fuse but by thenit blew instantly so after trial and error . i finnaly figured out when my deck was on it would blow a fuse. i have no idea iv checked wires their all good, btw i have 2 jl audio w3s and a memphis 1000d if that helps thanks adam
------------- 2 12 inch jl audio w3s stock infinity sound eclipse deck memphis 1000d
Posted By: acopsy88
Date Posted: April 29, 2006 at 2:38 PM
also if i put the illumination wire to the power wire it lights up and same with dimmer did i short them out how could i fix them do i need a new wiring harness adam
Posted By: forbidden
Date Posted: April 29, 2006 at 3:09 PM
you have more than likely grounded the CD3404 to the vehicle illumination wire. This wire shows ground when the lights are off and +12v when they are turned on. Disconnect the ground wire and test again. ------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: acopsy88
Date Posted: April 29, 2006 at 4:25 PM
ok now what will i expect will it still turn on thanks adam and if it is the ground what can i do to fix it adam
Date Posted: April 29, 2006 at 4:30 PM
No, the deck needs a new ground wire ran. Now that this wire is disconnected, do the lighting circuits work normally? ------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: acopsy88
Date Posted: April 29, 2006 at 5:46 PM
how do you run a new ground wire try a different spot or new whole wire adam
Posted By: godblessdremil
Date Posted: April 29, 2006 at 6:42 PM
just find a peace of metel that is connected to the body of the car. Put a lopp on the wire and bolt it to the metal.
Posted By: acopsy88
Date Posted: April 30, 2006 at 8:07 PM
ok i disconnected the ground wire and the illumination still doesnt turn on and the fuses are still good
