subwoofer wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=77363
Printed Date: April 19, 2026 at 9:59 AM
Topic: subwoofer wiring
Posted By: ugotjewed247
Subject: subwoofer wiring
Date Posted: May 06, 2006 at 12:33 PM
i have 2 dual 4ohm subs i wired them down to 2 ohms now i have to load them in a box that has 2 binging post but i have a 1ohm mono amp how should i wire it so the subs are at 1 ohm and both binding posts are used
Posted By: stevdart
Date Posted: May 06, 2006 at 1:16 PM
You have two 2-ohm subs (with coils in parallel).  A sub gets wired to each binding post on the box.  Binding posts must not be electrically connected to each other.  Now if your mono amp has double terminals wire from one post to one set of terminals; the other post to the other set.  If the amp has only one set of terminals, double up the wiring at the amp.
If the box binding posts are electrically connected to each other, run one set of wires from one set of posts to one set of terminals at the amp.  Alternative, if you want two sets of wires from box to amp:  connect both subs to one binding post.  On the outside of the box, run two sets of wires to the amp.
Date Posted: May 06, 2006 at 1:20 PM
hye how would i double up on the wiring??
its a 1ohm stable mono amp
Posted By: Steven Kephart
Date Posted: May 06, 2006 at 1:41 PM
Just connect all the positives together and all the negatives together and you will have a 1 ohm load.  But I don't get how you have them wired at 2 ohms now.  Is it wired 2 ohms stereo?  Because you can't have a 2 ohm bridged load while using all the voice coils.
Date Posted: May 09, 2006 at 3:16 PM
i have them in paraleel
