1996 contour stereo wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=77428
Printed Date: May 14, 2026 at 12:50 PM
Topic: 1996 contour stereo wiring
Posted By: mattilus2121
Subject: 1996 contour stereo wiring
Date Posted: May 07, 2006 at 11:36 PM
ok, Ive got the stereo on by connecting the constant power and the other power but I can't figure out how to wire the speakers, please help posted_image
Posted By: geepherder
Date Posted: May 08, 2006 at 9:07 AM
If you go to your local stereo shop, they will sell you a plug that you can wire directly to the new stereo matching wires color to color.  Then it'll plug into the factory harness and off you go.
Date Posted: May 08, 2006 at 1:59 PM
I bought the car connector kit but the actual speaker wire connecters didnt match up... was going to individually splice all 8 but the colors arent too much of a help.
Posted By: xtremej
Date Posted: May 08, 2006 at 3:33 PM
Read this topic, it should help.
Date Posted: May 09, 2006 at 6:10 AM
That sticky has some good info.  That means they sold you the wrong harness.  Ford uses several different harnesses.  If you go back to the store, they may let you look through their book to identify the correct one.
