Proper wiring and capacitors?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=77452
Printed Date: May 14, 2026 at 9:55 AM
Topic: Proper wiring and capacitors?
Posted By: mtmas8
Subject: Proper wiring and capacitors?
Date Posted: May 08, 2006 at 2:47 PM
I currently run a system in my car, 2005.5 audi a4, which includes 3 kicker cvr 12", 1 sx1250.1, 1 kx650.4, and kicker rs components in all 4 doors. I also am using a alpine Iva 300. I am running a 2nd battery and alternator is already a 120 amp. Recently I was hit in the trunk when waiting at a light at 65 mph. As you might've guess system does not work properly anymore.
I am looking to upgrade to (2) JL 13.5w7's each running on a JL 1000/1 amp and will run my speakers on a mtx 4 channel amp. I was wondering should i add a 3rd battery or is two enough? If so what is the "proper" wiring of all of these if the mtx amp is running off of the regular car battery and sub amp(s)? are running off one or two batterys? Also if i kept 2 batterys or upgraded to 3 would I need to add any capacitors or are they useless?
Posted By: saturnsubohio
Date Posted: May 08, 2006 at 2:52 PM
ehh 120 amps is not big enough for that much power...
even with the efficiency of a JL Amp, 120 amp alternator is the weak spot.
Sorry bout your accident, hope you werent hurt.
1.) Upgrade the "big three" by reading the stickies around here or searching around the web.
2.) a cap will be a bandaid for a larger problem and ultimately you have to have to power to recharge the batteries.
look for having an alt rewound
------------- 2006 WRX STI
Electrical Engineer
Ohio University Alumni
Posted By: xtremej
Date Posted: May 08, 2006 at 3:35 PM
Click on this link it has the information your looking for. -------------
Posted By: Aruman
Date Posted: May 08, 2006 at 4:13 PM
what mtx amp are you planning to use?
using 3 batteries on an not enough Alternator is not a good idea, i mean, 3 batteries, JL 1000/1 amp, MTX amp. the 120 A alt. will not be enough for that.
you'll need a bigger HO Alt.
------------- Shaking The Neighborhood
Posted By: mtmas8
Date Posted: May 17, 2006 at 2:54 PM
where could i purchase a HO alternator?
Posted By: mtmas8
Date Posted: May 17, 2006 at 2:57 PM
also a couple more questions, how should everything be wired if I used a two battery OR three battery system? What connectors, fuses, terminals, etc. would I need to wire all of this as well as how would I connect both my sub ampsto my deck. I have an alpine iva 310 touchscreen deck and it has three preamp outputs, but just one sub preamp? Thanks
Posted By: mtmas8
Date Posted: May 17, 2006 at 3:34 PM
Found places to buy HO alternators I am just wondering if I could get away with my 120 alt and some capacitors? Thanks
Posted By: jayson358
Date Posted: May 17, 2006 at 4:05 PM
no u should upgrade the big 3 then get a hold of ohio generators, mobile spec, or iraggi all three are ho altanators company usually they'll ask what was the size of the old alt and ask what will be the total current draw of the system and then they will build u an alt to the specs needed usually u send them ur old alt and they will rebuild it up to around 240-280amps about $500 any bigger u need 2 alt's or one huge alt requires bigger casing if everything is done right u dont need any caps now they say caps dont really do anything to save batteries but they r really to supply volts faster for the amps but all in all if u get a bigger alt and use a optima yellow top u dont need more than that one batt unless u play ur stereo for long periods of time with the car off jus suck it up and get the bigger alt save u allot of headaches and wallet pains in the long run do it right the first time right guys
------------- 93 diamante
pioneer deh-p3800mp
crossfire 40 band eq
alphasonik pma4075 mid amp
clif designs cd10.1Lx sub amp
powerbass xtreme 6 1/2 comp
" " 6x9 rear
alpine 2 12" type r
ported 40hz tune
Posted By: mtmas8
Date Posted: May 17, 2006 at 4:35 PM
thanks any specific way to wire dual sub amps to a deck? and how should i wire all amps to the one battery or two?
Posted By: luckydevil
Date Posted: May 17, 2006 at 4:39 PM
Take the money you were going to spend on caps and buy the most powerful alternator you can. Then go and do your Big 3.
https://stores.ebay.com/Iraggi-Alternator-and-Electronics
You may have trouble finding a drop in replacement since your car is so new. Having someone rebuild it may be an option.
