Adding sub box to bose system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=77522
Printed Date: May 15, 2026 at 1:20 PM
Topic: Adding sub box to bose system
Posted By: joegomez
Subject: Adding sub box to bose system
Date Posted: May 09, 2006 at 3:38 PM
    I just purchased a 2006 Nissan Altima S-ER that has the BOSE system, the system sounds good but it just does'nt have enough bass for me, I want to add a sub box, can this be done without replacing the head unit or burning up the factory amp.  A co-worker told me about the JL audio clean sweep ( I think that's what he called it ) he said that it was designed to work with factory amplified systems and that it would allow you to add a sub box, I haven't found anything info on it yet, can someone tell me about it, would this be the way to go?  Thanks for your response in advance.
J.Gomez
Posted By: gregory863
Date Posted: May 09, 2006 at 4:02 PM
jlaudioaheadofthecurve.com       you can also run a pre-amp adaptor for less $ i usualy solder my wires directly to the poles of the speaker to get my signal.
Posted By: forbidden
Date Posted: May 10, 2006 at 3:49 AM
If you want to do it properly, use the JL Cleansweep or I prefer the Audio Control LC6 + bass remote, this way you can control your sub indipendent of the master volume control and expand your system at a later date.
Posted By: joegomez
Date Posted: May 12, 2006 at 1:08 PM
Thanks for the inputs guys. Forbidden one other question, I looked on the JL Audio website and I noticed two clean sweep models which one is better for what I want, keep in mind that all I want to do is add a subbox and an amp.
J.Gomez
Date Posted: May 12, 2006 at 1:14 PM
j the cleansweep runs 399.95  a pre-amp adapter runs 29.95 for bass only the cleansweep is a huge wast of money. if you still want the sweep get hte newr one with the multi inputs.
I can eat fifty eggs
Date Posted: May 12, 2006 at 1:19 PM
IMO, I would use the Audio Control unit and add the bass remote to it so as to provide a separate level control strictly for your sub. Nothing is a waste of money when it provides superior performance. Yes there are two ways of doing this, the basic and inexpensive way or the advanced and costlier way.
