05 avalanche stereo
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=77588
Printed Date: May 15, 2026 at 1:24 PM
Topic: 05 avalanche stereo
Posted By: juancortezv
Subject: 05 avalanche stereo
Date Posted: May 10, 2006 at 9:24 PM
can i conect a amp to a factory stereo?,I got a 05 chevy avalanche,if i can,can i have the wiring diagram,can anyone healp me on this please,thank you
Posted By: tritippin24s
Date Posted: May 11, 2006 at 10:40 AM
I dont anything about the avalanche stereo, but I don't think so. Does your amp have hi-level input? If so, then just use that, as the stock stereo more than likely does not have RCA out. And remember, stock head units are usually larger, so don't get a aftermarket and expect it to fit easy if you were to get a new one.
Craig
Posted By: xtremej
Date Posted: May 11, 2006 at 10:47 AM
You can use a high level converter. It wires off speaker wires and converts the singnal to low-level line outs/rca's. Did you check in the diagrams section for the wiring info?
Date Posted: May 11, 2006 at 3:05 PM
yes, but converters add distortion and resistance
Craig
Date Posted: May 11, 2006 at 3:06 PM
Craig
Posted By: xtremej
Date Posted: May 11, 2006 at 3:14 PM
We use them frequently, never have had a problem.
Posted By: Hornshockey
Date Posted: May 12, 2006 at 2:54 AM
in my experience you'll get better results using a quality LOC than using the high level inputs on the amp.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
