Aux mode in DEH P7000R
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=77604
Printed Date: May 15, 2026 at 2:27 PM
Topic: Aux mode in DEH P7000R
Posted By: deveros
Subject: Aux mode in DEH P7000R
Date Posted: May 11, 2006 at 3:22 AM
Hi, does someone know how to turn in to AUX mode Pioneer DEH P7000R? I want to connect my PocketPC with CD Player using Disc changer switch. Thanks a lot!
Posted By: NowYaKnow
Date Posted: May 11, 2006 at 5:58 AM
On most pioneers push and hold the source button until the radio turns off. Then push and hold the function OR audio buttons until a menu comes up. That menu should have the aux on/off setting. Once you enable that you will see the AUX when you toggle through your sources. You would also need the ipbus to rca cable assuming your pocket pc would hookup via rca's.
Mike
