brutus, mrv-1507, or mtx 1501?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=77922
Printed Date: May 14, 2026 at 9:55 AM
Topic: brutus, mrv-1507, or mtx 1501?
Posted By: ralphpylayanum1
Subject: brutus, mrv-1507, or mtx 1501?
Date Posted: May 17, 2006 at 12:34 PM
i have 3 amps to pick out of the hifonics brutus 1600rms at a 1 ohm load 0.08 thd 95db per watt 160 amp fuse the alpine mrv-1507 or the mtx 1501 which amp would give me the be tight thump bass that im looking for its two l7's and they are wired at 2 ohms each if i paralell i get 1 ohm in series i get 4 thanks
------------- rafael rodriguez
Posted By: Aruman
Date Posted: May 17, 2006 at 4:18 PM
the MTX 1501D is a good Amp, it's rated 1500 @ 2ohm but MTX amps are underrated, so you will get more than that, about the Hifonics i heard that they're overrated but good amps if you are on thight budget and i don't know about the Alpine Amp, but i guest it's a good amp.
------------- Shaking The Neighborhood
