HO Alternator?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78067
Printed Date: May 14, 2026 at 10:02 AM
Topic: HO Alternator?
Posted By: Aruman
Subject: HO Alternator?
Date Posted: May 20, 2006 at 5:49 PM
 guys, i'm in a little situation here, and i want to check with you guys what i should do before i do something.
I'm planning to buy a HO Alternator, and i'm thinking about Ohio the reason why a choose Ohio is because they are very respectable and i have bad experience with other brand like Iraggi. but the problem is that the highest amperes Ohio Gen make for my car type(Toyota Corolla 2001 japanese style) is 160 Amperes Max and 75Amperes at Idle and since i have 1x MTX TA81001 160 amperes and 1x MTX TA3404 50Amperes and i'm also planning to install some Neon Light and some dvd monitors in the future, it will not be enought, other people told me to go with it others not, and the most important for me was the amperes at Idle, so guy what should i do, go for it or no? what do you guys recommend me? anyways, thnx a lot, Aruman.
Shaking The Neighborhood
Posted By: jeffchilcott
Date Posted: May 21, 2006 at 7:41 AM
I would reccomend getting out some cardboard and making templates of what it would take to fit a Large case GM style alternator on your car, if you want to most bang for the buck.
Typically it will take very little modification to fit a large alternator onto a smaller car, but I do not know your car very well.
I know you can fit a large case on a honda CRX and Honda civic with very very little modification.
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: adix5689
Date Posted: May 21, 2006 at 9:30 AM
I have a 2001 honda civic.  The biggest alternator I can get is a 170amps. Does anybody know if If there is a 200amp alternator for my car.   If I do some modification is there any other alternators out there that I can put in my car besides the ones made specificlly for my car.   I currently have one alpine mrd-m1005 and one mra-f350.  The current draw is about 60amps. When I turn the ac and headlights on the voltage reading drops to 13volts.  This reading is only at idle. I would like to add a couple of monitors, neon , and a dvd player later on.
Posted By: Aruman
Date Posted: May 21, 2006 at 3:32 PM
Thanks Jeff, here's the pic of my car's motor.
i doubt i can fit a larger case GM style Alt in it, i think i'll go with the Ohio, i don't know what's the higher Idle Amperes i can get from of Excessive Amperage. anyways, thanks a again Jeff.
posted_image
Posted By: speedwayaudio1
Date Posted: May 21, 2006 at 5:11 PM
That's pretty tight in there, but I bet you could get one in there. Go to a junk yard and buy a junk alt that is the same size as that Ohio. Then do some fab work to see if you can mount it. If you can, then order that Ohio. If you can't, you only spent a few dollars on that junk alt. I think you can do it. remember to upgrade your grounds and power wire's. See "The Big 3"  I think you could move your radiator over out of the way to. You pic does not show the left side of your car so I can be sure
Big Dave
Posted By: Aruman
Date Posted: May 21, 2006 at 8:45 PM
thanks SpeedW. no the Ohio can fit nicely, but since it's putting only 75A at Idle and 160A at max it will not be enough, the Idle Amperes is what is more important for me. if i can get one that put higher Amperes at idle it will be fine in my case.
I've already done the Big 3 as you can see in the pic. the white color 1/0awg cable in front of the Alt. the Alt you see in the pic is an Iraggi Alt. that supose to give me 120A at idle and 160A max, but when they test it for me, it's putting only 54A, so i have bad experience with Iraggi and that's why i'm thinking about an respectable brand like Ohio but again, there start another problem the not enought current at idle. anyways, thanks SpeedW.
Posted By: dwarren
Date Posted: May 21, 2006 at 8:55 PM
Even though your amps will pull more amperage than the alternator can produce, they will only pull those numbers at full volume during musical peaks. So unless you have the volume at a 100% all the time, I think the 160 amp alt will work.
Posted By: Aruman
Date Posted: May 22, 2006 at 12:18 PM
yep Dwarren your are right, and i can't play it at full volume all the time because i will be deaf if i do that. so Dwarren it should be fine to go with it, right? anyways, thanks Dwarren.
