Removing Seats From 05 F150
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78179
Printed Date: May 15, 2026 at 6:38 AM
Topic: Removing Seats From 05 F150
Posted By: vman
Subject: Removing Seats From 05 F150
Date Posted: May 23, 2006 at 10:19 AM
I'm getting ready to install 3 amps in my truck. I want to put them under the seats, because I am putting an MTX Thunderform 2-12 behind the seat, and I don't think there will be enough room there.
Has anyone removed the 60/40 non power seats from a base model F-150? The front screws seem accesable, but there is a plastic cover that makes the rear ones hard to get to. Any advice on removal and placement (easy guys) of the amps would be appreciated.
Thanks,
V
Posted By: Velocity Motors
Date Posted: May 23, 2006 at 11:53 AM
Does the amps have fans built in or are they strictly heat sinks ? Is there room behind the back seat area to place the amplifier's and also what kind are they ? Also the plastic bolt cover you can usually pry off with a screw driver or a pry tool.
------------- Jeff
Posted By: xtremej
Date Posted: May 23, 2006 at 12:18 PM
Do you have the thunderform, the reason I ask is some have a spot for the amp molded in the enclosure. Hittin' the big 10,000 posts today Jeff. -------------
Posted By: vman
Date Posted: May 23, 2006 at 11:05 PM
The Amps are:
(2) Rockford Fosgate 37.5 watt per side
and (1) Lighning Audio 250 Watt Sub Amp
None of the amps have fans, all heat sinks.
I have the Thunderform box, and it does not appear to have any place to mount an amp.
I'm thinkin' the only place these may go is under the seats.Remember this is the base model F150, no back seats.
Thanks for all the input........
V
Date Posted: May 24, 2006 at 9:40 AM
The thunderform amplified enclosures have the amps built into the enclosure & I have just reached the 10 G mark today  ------------- Jeff
Date Posted: May 24, 2006 at 9:42 AM
vman]T wrote:
e Amps are:
(2) Rockford Fosgate 37.5 watt per side and (1) Lighning Audio 250 Watt Sub Amp
V
Even if there's no back seats can you attach a MDF board on the back of the cab to attach the 3 amplifiers or does the enclosure take up this amount of room ? ------------- Jeff
Posted By: vman
Date Posted: May 24, 2006 at 9:51 AM
Jeff,
Congrats on the 10K milestone!
My Thunderform box is non-amplified. I have not tested it for fit yet (since I cannot figure out the seat removal situation) but eyeballing it tells me there is not going to be much room left back there. I would much prefer to do an installation like you are suggesting, but I don't think it's all going to fit......
Thanks,
V
Date Posted: May 24, 2006 at 11:34 AM
According to the instructions here you don't need to remove the seats at all, just slide them forward and your good to go. Also, from the pics that they used you can attach an amp between the two subs and one above each of the subs on the back of the truck. Attach an MDF board to the back of the Thunderform to stability and your good to go. ------------- Jeff
