running power cables
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78439
Printed Date: April 03, 2026 at 6:22 AM
Topic: running power cables
Posted By: djray_89
Subject: running power cables
Date Posted: May 29, 2006 at 9:07 PM
Hi guys,
im thinking of how to configure my wiring settings for my sub amp. can i run the +12 cable to the amp directly from the battery's + terminal and the amps ground terminal directly to the cars chassis where the amp is? can i run the amp without changing the OEM power cables from the alternator? its a 4 channel sony amp. im running 2 10" subs with it. (im thinking of running the amp with the OEM battery and alternator. will it work?)
Posted By: Ravendarat
Date Posted: May 29, 2006 at 10:17 PM
Yes you can and should run the 12V cable to the battery and ground the amp to the chassis and the altenator cable will be fine for the amp you are running.
------------- double-secret reverse-osmosis speaker-cone-induced high-level interference distortion, Its a killer
Posted By: djray_89
Date Posted: May 31, 2006 at 1:38 AM
Thanks Ravandarat for the info.
