4 0hm amp with a 4 0hm dvc
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78446
Printed Date: April 03, 2026 at 11:12 AM
Topic: 4 0hm amp with a 4 0hm dvc
Posted By: yourm0m1
Subject: 4 0hm amp with a 4 0hm dvc
Date Posted: May 29, 2006 at 11:00 PM
the amp is a vra4.0 cheapo i know and not good for wiring a sub, but the sub is an audiobahn aw105t i think its a 10" 4 0hm dvc rated at 300rms. i picked up the sub for like $25 a circuit city. now my question is, this amp is rated for no less than 4 ohms but i ran the sub earlier in series bridged to the amps rear output which would put the sub at 2 ohms. should i wire it in parrallel so it then becomes 8 ohms or just let it go with the 2 ohms since it was working tonight, just not a longer period of time? what would happen first though would the protection circuit kickin or blow a fuse or could the amp just become toast? just wondering its not really that important since the cost is cheap i can always swap the amp at walmart and the sub has warranty at cc which ill end up with a whole new model.
thanks for the input
Posted By: forbidden
Date Posted: May 29, 2006 at 11:36 PM
Wiring in series makes the sub 8 ohm. Wiring in parallel makes the sub 2 ohm. Chances are that the amp will go into protection and in time you will blow the sub. Here is how to wire the sub properly.
Option 2 (series) = 8 ohm load
Voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
posted_image
Posted By: yourm0m1
Date Posted: May 30, 2006 at 4:54 PM
thanks for the reply i plan on doing this in a bit ill check back with the results....
Posted By: kgerry
Date Posted: May 30, 2006 at 5:29 PM
or you could just run it as a SVC @ 4 ohms
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
