SXRC, Engine Noise Problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78452
Printed Date: April 03, 2026 at 2:31 PM
Topic: SXRC, Engine Noise Problem
Posted By: birdii
Subject: SXRC, Engine Noise Problem
Date Posted: May 30, 2006 at 12:23 AM
SX700.4
SX1250.1
SXRC Remote Control
posted_image
im getting some real bad engine noise when the wire to each amps are connected.... when i disconnect one side of the wire from any amp the noise goes away...
when the car is not on im not getting any noise...
when i shift into reverse i get no noise....
when im in park and the engine is on i get noise...
when im driving i get the noise.....
i tried moving ground but didnt help one bit...
not sure what to do please help
thx
Posted By: mustangfoo
Date Posted: May 30, 2006 at 12:29 AM
you probably have the wire running next to a power wire.  try re running the wire another route away from other cables.
Posted By: birdii
Date Posted: May 30, 2006 at 12:37 AM
all my power is running on the driver side and all the rcas are running down on the other side... :(  thx for the reply
Posted By: geepherder
Date Posted: May 30, 2006 at 6:29 AM
You have a ground loop.  If your amps are grounded at one common spot, try grounding the shields of the rca's as well and see if this solves the problem.  You can also connect the head unit ground to the amp ground with a jumper.
Posted By: spookiestylez
Date Posted: May 30, 2006 at 9:37 AM
You can buy a ground loop isolator for about $10-$15 most anywhere car audio is sold
sS
Posted By: killer sonata
Date Posted: May 30, 2006 at 9:43 AM
Dont buy something else to hide the problem. find the ground loop and fix it. A ground loop isolator is always a last resort and they dont always work.
