2002 sonoma zr2
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78777
Printed Date: April 07, 2026 at 1:10 PM
Topic: 2002 sonoma zr2
Posted By: djlayz
Subject: 2002 sonoma zr2
Date Posted: June 05, 2006 at 11:28 PM
I need to know what size speakers are in a 2002 sonoma zr2. I know the dash speakers are 4x6, but will 5 1/4" fit?I dont know the size of the door speakers.
Posted By: aznboi3644
Date Posted: June 06, 2006 at 12:38 AM
You can make them fit.
Posted By: Ravendarat
Date Posted: June 06, 2006 at 12:41 AM
5 1/4 wont fit in the dash, not without MAJOR custom work. As for the doors, they are 6 1/2 but you can make plates to hold 5 1/4 if you so desire.
------------- double-secret reverse-osmosis speaker-cone-induced high-level interference distortion, Its a killer
Posted By: forbidden
Date Posted: June 06, 2006 at 1:03 AM
Keep the speakers in the dash to either a 4" plate speaker, or a 4" component as part of a 3way set. The door speakers with the help of a adaptor plate will fit a 6.75" speaker.
------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: xtremej
Date Posted: June 06, 2006 at 9:46 AM
Use the adapter plates in the doors and either 4x6 plate speakers in the dash or 4" speakers. I just did this on my wifes zr2, I did componets in the doors after sound deadening installed new set-up, sounds many times better.
Posted By: djfearny2
Date Posted: June 06, 2006 at 9:49 AM
if you make a plate make it out of something that will not worp. if you use wood or masinite or something the outside temp will worp the wood. you can use plexi or something that does not change as easy to wether or get abs plastic plates premade. online or from local store.
------------- Jon
Installer/Help Technician
---coral springs florida---
