Alternator and battery worries
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78778
Printed Date: April 07, 2026 at 11:08 AM
Topic: Alternator and battery worries
Posted By: djray_89
Subject: Alternator and battery worries
Date Posted: June 05, 2006 at 11:30 PM
i am going to install 2 amplifiers in my Ford Laser Lynx. one for Door speakers, and one for 2 10" subs. I recently changed the stock battery to a new one with the same amperage(60 Amps). The alternator has a total amperage rating of 70 amps.Is it ok to run my 2 amps like this? (the 4 channel one is used for 2 subs, the other amp is for door speakers) any advise would be appreciated.
Posted By: aznboi3644
Date Posted: June 06, 2006 at 12:38 AM
Depends. 4 channel amps normally don't pull a lot of amperage.
First what kind of amps are these? Make and model and specs please?
I'd say turn the system up and if the lights dim with the beat than you need to upgrade the alternator. But first redo the big three. It will make a big difference.
