Power for 3 amps, Capacitor? deep cycle?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78890
Printed Date: April 06, 2026 at 2:43 PM
Topic: Power for 3 amps, Capacitor? deep cycle?
Posted By: freddykaye
Subject: Power for 3 amps, Capacitor? deep cycle?
Date Posted: June 08, 2006 at 1:34 PM
Long time reader, many many helpful topics, This is first ask for help. I have a 2005 F-150 supercrew, All kenwood kfc889 deck 1-9152d sub amp, 2-7252 amps for mid and highs, 14 speakers mostly mids and highs 2- X1002 subs. I had 2- pyle 1-farad caps. 1-for the 2 7252 amps ,and 1 for the subs. Stock battery and alternator (130 amp) headlights were dimming so I replaced 1-pyle for a 3-farad power acoustics cap for my subs. I just recently smoked my alternator (thank goodness for warranty) I cannot find a higher amp alternator (to new) and am considering a second battery, I have also been reading about Batcaps, are they like batterys of Capacitors?. I will probably go for a yellow top Optima (thanks to this forum) Also since my alternator took a powder, the power acoustics cap never reads above 14.3 volts wheras the Pyle fluctuates from 13 to 16 volts I have 0-gauge power wire to a distribution block and 4-gauge to the Caps and to the amps. The system also seems to be a little down on power. Any suggestions to keep my headlights bright? And not smoke another alternator? Its the audiophile in me.....thanks again for the Forum... John...
Posted By: jeffchilcott
Date Posted: June 08, 2006 at 4:03 PM
you should be able to have plenty of options for a high amp alternator with that vehicle.....look at ohio gen's, and domonick Irrage. And large case or delco alternator will fit that car without a problem
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: aznboi3644
Date Posted: June 08, 2006 at 11:39 PM
big three?
Date Posted: June 09, 2006 at 1:17 AM
Thanks for the big 3 advice, it gives me new hope.... Maybe I havent spent as much time here as I should...
Date Posted: June 09, 2006 at 1:19 AM
Thanks for the reply, Maybe I just havent looked hard enough, I'm going to try the big 3 this weekend...
Date Posted: June 09, 2006 at 7:49 AM
Good luck...Big three does make a world of a difference.
Date Posted: June 09, 2006 at 10:43 PM
Thanks for the advice, I found several companies for a high amp, (shoulda looked on the net first) Big 3 tomorrow...
Date Posted: June 09, 2006 at 11:20 PM
good luck
