1999 mustang stereo
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78947
Printed Date: April 07, 2026 at 3:51 PM
Topic: 1999 mustang stereo
Posted By: allanjames
Subject: 1999 mustang stereo
Date Posted: June 09, 2006 at 9:56 PM
i  just want to replace cd player in two piece radio cd player they are seperate, i have i dvd player that has rcas out. i'd like to tap in to exesting system keeping radio using amp and speakers, if i could find the wiring scematics for the cd player im sure i could patch in ,and have dvd mp3s
Posted By: jeffchilcott
Date Posted: June 10, 2006 at 11:33 AM
The factory amp in this car has a high level input from the factory deck.    You will not be able to "patch into" the factory system.   You will only be able to remove the factory amp which is located in the bottom of the dash in the very center.
Then you will have to add an aftermarket amp that will take your low level inputs (RCA"S)
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Date Posted: June 10, 2006 at 12:16 PM
as i stated the stereo is two piece i want to use the cd input heres a pic of the stereo i want to keep the radio part and replace the cd player with a dvd player ,the dvd has only preouts and no radio thats why i want to keep radio portion any one with the wiring diagram for this stereo?posted_image
Date Posted: June 10, 2006 at 12:47 PM
I have the radio, cd player, and amp laying around somewhere and I think I metered all the wires before I took it all out and labeled them.    I will look in storage later tonight and see what I can come up with.
2007 World Record
Posted By: domiyork8091
Date Posted: June 10, 2006 at 1:08 PM
I will just use an FM Modulator, I think that will be the easiest.
Date Posted: June 10, 2006 at 5:44 PM
i hadent thought of that ill look into that today and thanks to both for the help
Date Posted: June 10, 2006 at 6:14 PM
thanks id apprcaite that
