2000 Silverado speakers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7925
Printed Date: March 26, 2026 at 4:36 AM
Topic: 2000 Silverado speakers
Posted By: JohnnyMac
Subject: 2000 Silverado speakers
Date Posted: January 10, 2003 at 3:47 AM
I'm a little confused concerning my 2000 Silverado stereo. (Z-71, ext. cab, 3 door, type LT)
The first thing I find interesting is that all references I've seen about the rear speakers location, (including this site) say "rear pillars". They're in the doors.That's no big deal, although I would have used larger rears in my sound system upgrade had I known how much room there is in the doors.
The main question I have is... There is no reference anywhere to the fact that the front speakers are components, and have two seperate harnesses per door. Are these in parallel somewhere between the deck and the door?
I'm not sure how to wire my Infinity components. (with passive crossovers)
Any help is appreciated!
JohnnyMac
Posted By: Velocity Motors
Date Posted: January 10, 2003 at 9:31 AM
You will need to run new wires. This is a common problem with the 6 speaker systems in most vehicles. If you have a OEM amplifier and try to hook up the aftermarket deck to this amp, you may experience alot of distortion because of bi-amplifying the signal.
