12'' 8 ohm sub problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79338
Printed Date: May 14, 2026 at 7:58 AM
Topic: 12'' 8 ohm sub problems
Posted By: neon bright
Subject: 12'' 8 ohm sub problems
Date Posted: June 19, 2006 at 4:55 PM
AA buddy of mine sold me a 12 inch MTX thunder 4000 8ohm sub and a phaser Linear 240 watt amp, I hooked everything up properly but it sounds kinda crappy, any ideas as to what the problem is?
Posted By: fakepete
Date Posted: June 19, 2006 at 5:15 PM
Do you know the specs on the amp? The amp is probably rated for 4 ohm, not 8ohm. The speaker might only be getting half power.
Date Posted: June 19, 2006 at 5:46 PM
ifIf the amp is only rated for 4 ohm, does that mean that I need to find a new amp or is there something I can do?
Posted By: DYohn
Date Posted: June 19, 2006 at 5:56 PM
It's not a problem, car audio amplifiers are rated for the MINIMUM load they can handle. Placing higher impedance loads on them is just fine. ------------- Support the12volt.com
Posted By: DYohn
Date Posted: June 19, 2006 at 5:58 PM
What kind of enclosure is the speaker in? Also, "Phase Linear" car audio amps are very marginal quality, so you cannot push it too hard or it will generate 100% distortion. ------------- Support the12volt.com
Date Posted: June 19, 2006 at 6:09 PM
tThe enclosure is sealed box, and I'm guessing that the amp is why it kinda sucks, is there any decent, cheap amps?
Date Posted: June 20, 2006 at 5:20 PM
III decided to take the amp back, I can get a Sony 440 watt amp, are they any good?
Posted By: aznboi3644
Date Posted: June 20, 2006 at 7:03 PM
I'd get a kenwood over a sony amp.
Sony 440 watt would be crap.
