Advice required for a newbie
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79840
Printed Date: May 13, 2026 at 12:04 PM
Topic: Advice required for a newbie
Posted By: the toad
Subject: Advice required for a newbie
Date Posted: July 01, 2006 at 11:08 PM
Hello,
I would like to ask for some advice, I am currently looking at replacing my stock system.
The system I am looking to install is as follows.
Head unit Alpine Cda-9853 ( or 9857 still deciding) Front Alpine SPR-17ls Splits Rear Alpine SPR-69lp 2 ways Amp Alpine ?????? not sure yet.
Any opinions on the system?
My main question is due to lack of space behind the rear seat of a twin cab Ute, I have to make a box to fit out the speakers and amp and can not fit a sub, the basic dimensions I have to work with are L 800mm (31") H 180mm(15") depth base 180mm(7") depth top 40mm(1.5").
Now being a total novice at box building I had planed on building a complete full length box to those dimensions and just sinking the amp into the centre of the box, Am I better off building two sealed speaker boxes and just mounting them to a back board the full length creating two sealed boxes or is one full length box with no divide between the speakers making a much larger cavity space going to be ok
My main objective for this is due to no sub space I am wanting to get some nice bass from my rear speakers, not looking for Doof Doof, However I do want to get good sound (for those songs that come on that you know you just have to crank it up.)
Thanks in advance
Daniel
Posted By: forbidden
Date Posted: July 02, 2006 at 12:50 AM
Daniel, stop the bus and get off. I think you are on the wrong one. Read the stickies at the top of this forum as there is a huge amount of advice there. I see Alpine is a favorite for you, any particular reason why?
------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: the toad
Date Posted: July 02, 2006 at 1:22 AM
Hello Rob,
LOL Can you tell me which bus to get on?
I have been through most of the stickys and I am either not reading them right or just don't seem to be getting the answers I'm looking for ( it may be just how I'm asking them I guess).
Basicly I want to know if I build an enclosure to hold my rear speakers and amp am I better to build with one open cavity the full length of the box or seperate each speaker in there own enclosure?
As to Alpine my Fav I guess it's a case of stick with what you know. Yes I like the gear and I like a matched set up,
However open to options
Thanks daniel
Posted By: mustangfoo
Date Posted: July 02, 2006 at 3:10 AM
Alpine is ok, but there are better things out there. Kinda like sodas, off brand is ok, but there are better quality sodas out there. Anyways as for the box you want to know is basically something like this. . . Is it better to make a lets say just for an example of how you want your box, not saying to use these dimensions, but a 48"x19"x18" OR is it better to build TWO seperate boxes 24"x19"x18" Neither would be the answer to that question if that is the question. Build the single box, but in the middle on the inside put a piece of wood to divide the box into two seperate chambers as it would be two seperate boxes put together.
Posted By: aznboi3644
Date Posted: July 02, 2006 at 3:12 AM
Separated enclosures is a better bet.
If one sub fails the internal volume doesnt not double and make the sub suck and potentially fail.
Posted By: the toad
Date Posted: July 02, 2006 at 3:43 AM
Hey thanks for the reply guys,
That basically answers my question. Now remembering that I'm looking to use 6x9 and not subs do I need to have a certain sized enclosure for each speaker?
What I am trying to achieve is a good combination of full range tones with some solid Bass
Am I going about this the wrong way?????
Cheers Daniel
Posted By: jeffchilcott
Date Posted: July 02, 2006 at 7:30 AM
my 2 cents. Ditch the 6x9s and go for a single 8 or 10 inch sub. use a solid alipne 4 channel amp if you want to use all alpine, and bridge 2 of the channels to run a single sub.
I think this might be the answer rob was poking at before.
I think he meant to browse through the advance front stage topic....
I good front stage will support all the highs you may desire and then you can add a sub to get the low end you would like to have as well
The Alpine type E (if they are still around) were quite shallow, required very very little airspace and power, and sounded as any alpine should. Great!
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: stevdart
Date Posted: July 02, 2006 at 8:51 AM
Jeff is correct. The other two responses given above obviously didn't notice that you said that you were not using subs.
------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Date Posted: July 02, 2006 at 1:32 PM
That's the thing about being in Western Canada, everyone answers the next morning when you are still looking at the ceiling saying "why do I have to get up today". That is where I was going as well. I would do the exact same scenario and choose a shallow mount sub for your ute. Pioneer makes some good shallow mount 10" and 12" subs that take a super duper small sealed enclosure that will fit your ute. If you want my opinion on a cd player, it will be Eclipse, after that you can do what you like but the choice of a headunit like the one I am mentioning will make a huge difference to your system. Look at the CD2000, CD3000 or CD4000 as there is no difference in them for tonal response, bells and whistles only. www.eclipse-web.com.au
Date Posted: July 02, 2006 at 3:19 PM
maybe I am just a silly midwesterner but I will need to look up what this so called UTE is....im not familiar with them. haha
2007 World Record
Posted By: the toad
Date Posted: July 03, 2006 at 5:50 AM
Thanks again for the replies, lol looks like I’m going back to the drawing board
I also want to thank you guys for hang in there with me, like I Said I’m a newbie to this and don’t know jack, so really relying on the experts here to guide me in the right direction.
lol Jeff, if I said it was a four door pick up truck, would that make sence???
Ok more research now looking at the Pioneer shallow mount 8” TS-SW841D
I don’t seem to be able to find the information on mounting depth on the 8”. If it is the same depth as the 10” It will not fit in the space I have to work with
If I keep with the idea of splits in the front, and only run a sub in the back will the passengers in the rear still get good sound?? ( this is why I was first thinking of rear speakers)
And if I can’t fit a sub what options do I have to get good sound and bass in the back???
Thanks again
Daniel
Posted By: Flakman
Date Posted: July 11, 2006 at 4:40 PM
LOL as well. Reminds me of "My Cousin Vinny". ------------- The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
Posted By: kfr01
Date Posted: July 11, 2006 at 6:15 PM
Daniel:
Try things without speakers in back. Forbidden will probably have the opposite opinion. But you can always add speakers to the rear latter, right?
I would really try to fit a sub. Alternatives simply can't achieve the same bandwidth (easily).
As for the amp. Try this:
https://www.eclipse-web.com/amp/xa4000.html
Digital, so you don't have to worry much about upgrading "the big three" right off the bat.
To start out, use the first two channels for your front "splits." Use the second two channels, bridged, to your subwoofers. I also like that this amplifier has very flexible crossovers, so you're set even if your head unit does not have many options. It is pricey, but buy it under warranty and you'll likely never need or want to buy another amplifier.
Good luck!
------------- New Project: 2003 Pathfinder
Posted By: the toad
Date Posted: July 29, 2006 at 1:33 AM
Thanks for the reply Kfr01
Looks like that is the way I am going
Well this is what I got so far.
I went with the Alpine CDA-9853 ( I like the Alpine gear and I am used to the systems, besides I got it at a price that I just couldn't say no.)
MB Quart RCE-216 6.5" ( fitted in the coaxial option for ease of install)
Amp and sub are put on hold ( the wife found out what I'm doing so just laying low at the moment)
However still looking at a shallow mount sub, high on the list is the Earthquake SWS due to the total lack of space I have to work with the Pioneer and some others I have looked at are still to large.
Now for some more stupid Questions from me.
It was suggested to me that since I am only using front speakers chanels, I should wire my Splits using the 4 channels of the head unit, the woofers to the rear channels and the Tweeter to the front channels. Giving me the option of fading the Tweeter in and out with more ease.
Is this a good option and if so are there any great advantages to do this. And when I get my amp do I then need to look at a 6 channel 2x woofer 2x tweeter and then 2 bridged for sub?
Cheers
Daniel
Date Posted: July 29, 2006 at 2:35 AM
Nope, just run the components normally. The crossovers have a built in attenuation circuit on them to adjust the levels if things are too bright in relation to the woofer. Wait and buy the XA4000 (putting one in a boat right now (literally at 12:30am)), you can't miss with an amp like this. You can tell the wife it is part of the speaker package. ------------- Top Secret, I can tell you but then my wife will kill me.
Date Posted: July 29, 2006 at 2:36 AM
And yes my opinions are usually different.  ------------- Top Secret, I can tell you but then my wife will kill me.
