which way to hook up for the most power?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8005
Printed Date: March 27, 2026 at 5:30 AM
Topic: which way to hook up for the most power?
Posted By: brianh
Subject: which way to hook up for the most power?
Date Posted: January 11, 2003 at 4:44 PM
I am going to be installing two MTX 4000 in a baffle in the back of a Camaro.  I will be pushing the subs with a Phase Linear amp.(100x 2) It is bridgeable.  The subs are 4 ohm.  How could  I wire this up for the most power?  Could I wire them in series and then bridge them to the amp? Any help on this matter would be great.  Thanks again.  Brian
Posted By: Velocity Motors
Date Posted: January 11, 2003 at 5:06 PM
Depends on the amp . If the amp is stable to 2 ohms then use this configuration:
posted_image
Posted By: brianh
Date Posted: January 11, 2003 at 5:42 PM
I could hook them in parrallel and bridge them to the amp?  Will that be a two ohm load? Thanks brian
Date Posted: January 11, 2003 at 11:10 PM
If they are SVC 4 ohm subs then the above configuration will give you a 2 ohm load.
