86 camaro, thump advice
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80421
Printed Date: March 31, 2026 at 4:15 AM
Topic: 86 camaro, thump advice
Posted By: irocthump
Subject: 86 camaro, thump advice
Date Posted: July 17, 2006 at 11:24 PM
Im new. And stupid. so bare with.
I have an 86 camaro and i wanted to get some thump and my friend offered to sell me 2 not even used 12in Power Acoustik subs (now i here that there crap subs or something)for 150 .and so me and a buddy set off to build a box and we were able to but then he noticed that the are between the 2 12s was just big enough to safely mount a 10. so i picked one up and about a half a month later i have my amp turned up to about 80% power ( its a 2000 watt) and i noticed that on certain songs the 10 hitts like mad but my 12s do almost nothing. My buddy told me that the 10 was cancelling the current or something.
So i beg of you Help me! I have almost no idea whats going on and i dont wanna scrw anyhitng up. And remember...Im A NOOB and STUPID.
Im A SkEEzeR
Posted By: jeffchilcott
Date Posted: July 17, 2006 at 11:47 PM
your frind is probably right, running diffent brand and size of subs is a big no no.   they can very easily cancel the waves of the other subs.    pick a woffer and stay with the same size and brand and model.
do not mix unless you plan to spend money of seperate amps and lots of processing or your sound
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Date Posted: July 18, 2006 at 12:10 AM
dam. i was afraid of that. So my solution is get rid of the 10. OK. Bout if i do that AND want to buy a third 12 (Its just a personel thing. IM sure 2 would thump just as hard) would my amp be enogh(The 12 are rated at 1800 watts apiece)? IM just unsure of pretty much anyhitng.
Im A SkEEzeR
Posted By: aznboi3644
Date Posted: July 18, 2006 at 12:41 AM
What amp do you have??? For an amp that puts out 2000 real watts would cost a pretty penny.
If you want to buy another 12 then check first if the amp can safely handle the impedances that you wire it up for.
Date Posted: July 18, 2006 at 12:08 PM
I have an American Legacy 2000watt amp. I know now that that brand is junk and now im just waiting for the thing to take a poopy and ill probly get something a whole lot nicer. But it was cheap and easily available to me so i picked it up.
Im A SkEEzeR
Date Posted: July 18, 2006 at 12:32 PM
Well I guess crank that baby up and wait for it to take a duece...
Cheap but reliable amp is the Kenwood KAC-9102D or the 9152D...can get either for under 200.
Date Posted: July 18, 2006 at 4:37 PM
By adding a 3rd sub your just streaching the real world 500 watts that amp is pushing even further.    I would stick with the 2 12"s and call it a day
2007 World Record
Posted By: coppellstereo
Date Posted: July 18, 2006 at 7:51 PM
how do you have all 3 subs wired?
is the amp a mono block?
what impedence are the woofers
are you sure that the 12's arent wired out of phase?
Date Posted: July 18, 2006 at 11:20 PM
Thre wired in parrelel/series (got the diagram off this site). My amp is a 2 channel and my woofers are 4ohm.and im not sue what u mean by out of phaseposted_image
Im A SkEEzeR
Posted By: geepherder
Date Posted: July 19, 2006 at 6:31 AM
It concerns me that you said you had your amp turned up to 80% power.  I'm thinking you mean your amp gain control- do a search in this forum for how to set gains.
If you unplug one of the rca's at the amp (left or right) and it gets louder, switch the two wires around on one of the subs (that means their out of phase, and one sub is cancelling the other).
