2001 Denali, Best place to pickup RAP
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80511
Printed Date: May 14, 2026 at 12:08 AM
Topic: 2001 Denali, Best place to pickup RAP
Posted By: tkur
Subject: 2001 Denali, Best place to pickup RAP
Date Posted: July 19, 2006 at 10:46 PM
Can someone sugget the best place to tap into RAP.  I need to tap several things into it and want the strongest or best place to get it.
Posted By: KarTuneMan
Date Posted: July 20, 2006 at 3:12 AM
ACCESORY........ Yup!    Think Man, think!
Posted By: tkur
Date Posted: July 21, 2006 at 6:59 AM
I guess I'm just not sure where to tap into it.  Can I grab it right at the fuse box?
Thanks.
Posted By: josh1979
Date Posted: July 21, 2006 at 7:50 PM
big white wire in the main ign. harness
12volts red  +  ignition harness
Starter yellow  +  ignition harness
Second Starter N/A
Ignition pink  +  ignition harness
Second Ignition white  +  ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition N/A
Accessory orange  +  ignition harness
Second Accessory brown  +  ignition harness
Keysense lt. green  -  ignition harness
Power Lock lt. blue  +  pin A4, brown plug at BCM
Notes: The BCM (Body Control Module) is located behind the driver side of the dash. The plugs face towards the rear of the vehicle.
Power Unlock white  +  pin A3, brown plug at BCM
Lock Motor gray  5wi driver kick, door harness
Unlock Motor tan  5wi driver kick, door harness
Parking Lights+ brown  +  pin B6, lt. blue plug at BCM
Parking Lights- white  -  pin A5, lt. blue plug at BCM
Hazards same as turn signals
Turn Signal(L) lt. blue  +  steering column
Turn Signal(R) dk. blue  +  steering column
Reverse Light lt. green  +  inside rear view mirror
Door Trigger   -  BCM
Notes: Use tan for the driver door located in pin B4 of the purple plug, and the passenger doors are a blue/white in pin B11 of the lt. blue plug. Use both wires and diode isolate each.
Dome Supervision use door trigger
Trunk/Hatch Pin pink/black  -  pin B10, lt. blue plug at BCM
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms on lock
Factory Alarm Disarm lt. green  -  pin B3, purple plug at BCM
Disarm No Unlock see factory alarm disarm
Tachometer white  ac  ECM
Notes: The ECM (Engine Control Module) is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the tach wire is at pin 20 in the connector labeled red. On the 4.8L, 5.3L, and 6.0L, the tach wire is located at pin 10 in the red connector.
Wait to start dk. blue  -  instrument cluster
Brake Wire white  +  brake pedal switch
Parking Brake GREEN / WHITE  -  parking brake switch
Horn Trigger black  -  pin A9, brown plug at BCM
Memory Seat 1 white  +  memory mod under dr seat
Memory Seat 2 purple  +  memory mod under dr seat
Memory Seat 3 N/A  +
posted_image
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Passlock II
Part #: 556LW
Alternate Part1 #: 555LW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes:
Door Lock Interface
Required:
No
Type:
N/A
Part #: N/A
Notes:
Combo Interface
Required:
Yes
Type:
Data Bus
Part #: 457GW
bring back the rotary phone so i dont have to press 1 to proceed in english
