SPL Setup
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80791
Printed Date: May 13, 2026 at 12:04 PM
Topic: SPL Setup
Posted By: blackmica3
Subject: SPL Setup
Date Posted: July 26, 2006 at 12:40 PM
Heres my dilemna. I'm just getting back into wanting to compete. So I'm going over every option for my vehicle. I have a 2000 Extended Cab Chevy 1500. I want to do 4 12" subs where the back seat is at now. Removing the seat of course. My question: When looking for subs would excursion play a factor for you guys? Keep in mind I'll be competing SPL only. The reason I ask is the two brand of subs I'm looking at that are readily available to me have the following excursion: 14mm and the other has 18.7mm. Both are rated at approximately the same RMS, 600rms for the 14mm and 500rms for the 18.7. Brands: Rockford Fosgate T1 and Dayton MKIII I want RE, but I am having a hard time finding them readily available. Other recommendations to me have been the 12" Memphis MOJO. But they require 3cu.ft per sub for vented with an RMS of 1000. And I'll only be pushing 2000 watts RMS. Any recommendations would be appreciated.
Posted By: coppellstereo
Date Posted: July 26, 2006 at 3:45 PM
Maybe look at cone area and excursion together
Posted By: haemphyst
Date Posted: July 26, 2006 at 5:14 PM
For LOUD, with no regard for SQ, I would also recommend looking into Cerwin Vega, or something with a much shorter excursion capability.
Long throw woofers will RARELY, if ever equal the output capabilities of a shorter throw woofer.
Here's a thread regarding this. ------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
Date Posted: July 26, 2006 at 5:37 PM
Yeah, they are trying to talk me into 4 T1 15" Rockford Subs. The price is right $275 per sub. But then I'll have to up my amp. I only wanted to run 2000 watts, but with 4 T1 15" I figure I would want at least 4000 watts. Now we're talking high output alternator, 2 batteries, etc. I don't know if I want to go that big. I mean it would be nice to be in the high 140's to 150's, ahhh I don't know. We'll see. If I get started here with it, I'll keep you guys posted with pics.
Posted By: Flakman
Date Posted: July 26, 2006 at 5:38 PM
Whiskey, Tango, Foxtrox...OVER! My head is spinning like the day after a bottle of Patron! Ham...I'm going to have to search through all of your posts now and compile an audio reference manual (I'll have to include DYohn as well). Always good stuff from you guys. Always something that makes me glad I joined this forum. BTW...nice SIG change. ------------- The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
Posted By: jeffchilcott
Date Posted: July 26, 2006 at 5:39 PM
You Rang? haha Excursion has some benifits, but it also can cause alot of failure.
Here are some comparisons for you
(2) 12" DD9512 with 3382 watts = 148.6db
(1) 12" Rockford T2 with 2487 watts = 145.3db
(2) 12" KICKER L7's with 3382 watts = 152.2-153.1
(2) audiobahn 10inch prefab bandpass subs in custom box with 682 watts = 142.2 hmmmmmmmmm
If you really want to get into my notes and disscuss some things I would glady do so, send me a PM with your phone # and I will give you a call
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Date Posted: July 26, 2006 at 5:42 PM
^^^^You have PM. Thanks!!!!
Posted By: 12vdeej
Date Posted: July 26, 2006 at 5:48 PM
I may be the only person on this forum that does this, and there may well be a good reason for that, but you could consider using pro audio drivers rather than automotive components. The reason for doing this is the massive increase in sensitivity, giving you much more volume for the amount of input power you have available. To give you an idea of the difference the new JL audio 12W3v3 has a sensitivity of 87.15dB 1W/1M, whereas the eminence delta 12A i use (x2) in my sub has a sensitivity of 98.3dB 1W/1M. This equates to around 10 times the power input to the JL driver than the eminence driver to make the same SPL. The downside is that excursion on pro audio drivers is significantly lower. I decided to try doing this because of my pro audio background, and so far i am very pleased with it. I'd like to know if anyone has any opinions on not using automotive/mobile audio components. You may find it interesting, while im blabbering on about sensitivity, that i've built a horn loaded sub that has an efficiency of 102dB 1W/1M and with a 350W input from my amp will blow the bloody doors off! The picture below shows the sub missing its side so that you can see the horn section (which is 7 feet long!)
Posted By: forbidden
Date Posted: July 26, 2006 at 8:11 PM
DD has been making great waves in the SPL lanes as of late.....funny thing....it has been making waves here at a SQ based store as well.....  ------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: stevdart
Date Posted: July 26, 2006 at 8:36 PM
Long excursion is a by-product of two factors: greater and cheaper availablity of POWER, and the need for SMALL ENCLOSURES in automobiles. Search Steven Kephart (author) or excursion (message body) for several discussions regarding this.
------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Date Posted: July 26, 2006 at 9:03 PM
What do you folks think of the 18" Solo X? Jeff? Stevdart?
Date Posted: July 27, 2006 at 7:35 AM
I know I have one I havent played with yet.....I think I am going to get going with it this weekend.
I helped a guy get to 152db on 1 solo x 18 with (2) 2500.1 on it
2007 World Record
