sub wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80867
Printed Date: May 13, 2026 at 8:49 PM
Topic: sub wiring
Posted By: grandamgt818
Subject: sub wiring
Date Posted: July 27, 2006 at 9:41 PM
if i have 2 mono amps and 2 single voice coil 4 ohm subs i should be able to do this right..
wire the negative from one sub to the negative on one amp and the positive to the positive on the other amp. then vice versa with the other sub.
this would give me a 2 ohm load on both amps right?
Posted By: killer sonata
Date Posted: July 27, 2006 at 10:05 PM
that is called strapping and can only be done if the amps are capabale of that. Chances are they arent. There arent many amps that can. What are the make and models of your amps?
"People with mullets live 40% longer"   - Ricky Bobby
Posted By: Flakman
No. No more than one amp per speaker or speaker set.  You cannot hook up the output of multiple amps together to the same load. You could hook up the two woofers like this:
posted_image
...but you could only hook them up to one amp.
The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
Date Posted: July 27, 2006 at 10:07 PM
right on flakman, i was just looking that up. grandamgt818, use the above picture to wire 1 of you subs to 1 amp and the same with the other sub and amp.
