New System Plans
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81060
Printed Date: April 25, 2026 at 12:24 PM
Topic: New System Plans
Posted By: cloak559
Subject: New System Plans
Date Posted: August 01, 2006 at 2:01 PM
Well, I finally blew that crappy Power Acoustik Silver Edition...Melted the voice coils on it.....But this just gives me a reason to upgrade. I had the problem of not being able to truely get the full potential of my system, because I have classic Mercedes, and there's a gas tank and two metal walls seperating the trunk from the cab. I still get bass through, but the SPL was definately not sufficient. So next week im going with a Rockford P-3 12". Right now im building a ported box for it that im going to cover in vinyl. Im also going to port the trunk to the rear shelf so that the sound gets through. Should be an interesting project, i'll post up some pictures next week as it comes together......But what do you all think of my plan? ------------- '89 Mercedes-Benz 300E
Pioneer DEH-5900UB
(2)RE Audio SX 10"s
(1)US Amps MD3D
3ft^3 @ 37Hz
Blowing up in a car accident doesnt worry me, as long as I'm putting out some major dB's when I die...
Posted By: xtremej
Date Posted: August 01, 2006 at 3:09 PM
Sounds like your going to be busy. Only advice I have is if plan on cutting the rear shelf, remember on most vehicles this is a major part of the structure. I am not sure on your mercedes but on the cars I have done it was. It kind of depends on how your doing this, but I figured I would remind ya. Maybe if you take some pics of your deck lid/rear shelf and post them you'll get some ideas on how to do it.
Posted By: cloak559
Date Posted: August 01, 2006 at 3:28 PM
Well, I can see the rear speakers through the trunk with a flash light and theres really only one support bar I can see running across the underside. So I think im just going to run the port out where the rear speakers are and put some 6.5's in the door...Im taking it by a stereo shop later to see what they think...
Pioneer DEH-5900UB
(2)RE Audio SX 10"s
(1)US Amps MD3D
3ft^3 @ 37Hz
Posted By: supersix4
Date Posted: August 01, 2006 at 3:51 PM
Installing speakers in the rear doors will sound like **** when compared to the factory rear deck location ... Don't Do It!! PLEASE PLEASE PLEASE - Don't cut up a classic Mercedes' doors!! Take the rear seat & rear deck out. Get a 2" or 3" holesaw. Have a blast - watch out for the Fuek Tank!! Then put the interior back together. It'll look factory, but sound better. I've done this before - it'll work. The Trunk & Passenger Compartment are seperated by the steel bulkheads due to the Fuel Tank location. Be aware that cutting holes in these steel bulkheads will put folks at risk (exposure to fuel leaks as a result of collision) in the event of a collision ... but the car will sure sound better ... -------------
Posted By: cloak559
Date Posted: August 01, 2006 at 3:56 PM
Blowing up in a car accident doesnt worry me, as long as I'm putting out some major dB's when I die...As for the rear door speakers, I wasnt really hard on that, it was just a thought. Most likely ill have it port through somewhere else and leave the speakers in the stock location. Though I am going to cut the speaker mount to make room for some 5-1/4"s... ------------- '89 Mercedes-Benz 300E
Pioneer DEH-5900UB
(2)RE Audio SX 10"s
(1)US Amps MD3D
3ft^3 @ 37Hz
Posted By: geepherder
Date Posted: August 01, 2006 at 6:29 PM
If you have that first aid kit/storage compartment installed in the rear deck, why not remove that, and place it in the trunk? Then you can just build a perforated panel and cover it with carpet or grill cloth.
------------- My ex once told me I have a perfect face for radio.
Posted By: stevdart
Date Posted: August 01, 2006 at 7:08 PM
Blowing up in a car accident doesnt worry me, as long as I'm putting out some major dB's when I die... Classic. That should be your sig line ;) ------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Posted By: cloak559
Date Posted: August 01, 2006 at 8:00 PM
Unfortunately my model didnt have that option. Its allright, its not gonna be that difficult of a task... stevdart wrote:
Blowing up in a car accident doesnt worry me, as long as I'm putting out some major dB's when I die...Classic. That should be your sig line ;)
You read my mind... |
Pioneer DEH-5900UB
(2)RE Audio SX 10"s
(1)US Amps MD3D
3ft^3 @ 37Hz
