Speaker wiring test
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8110
Printed Date: March 28, 2026 at 8:55 AM
Topic: Speaker wiring test
Posted By: jcaimhigher
Subject: Speaker wiring test
Date Posted: January 13, 2003 at 9:20 PM
Is there a way to test the speaker leads from the radio at the speaker in the doors?  Basically, what would we want to test with the voltmeter?  120v range or??  I think the speakers may be wired wrong, not terrible sound, just a feeling after the new deck was put in...kinda hard to remove.
Thanks for the input!!
John
John
jcaimhigher@ixpres.com
Bond of the Blue Beret
Posted By: jsitterly
Date Posted: March 15, 2003 at 8:54 AM
check the polarity off your speaker with your ohm meter then go to wireing color codes of your vehicle match  + w+     - w- .if the speaker does a inword pull you have th - and + possitiv reversed if you dont know were un hook one speaker at a time until you find your reverse wire dont forget to mark the wire you have wrong with a piece off tape so the next installer doesent experience the same problem...
