those w/amp undr drvr’s seat 03-06 accord
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81270
Printed Date: April 01, 2026 at 7:50 PM
Topic: those w/amp undr drvr’s seat 03-06 accord
Posted By: saxdogg
Subject: those w/amp undr drvr’s seat 03-06 accord
Date Posted: August 06, 2006 at 1:12 PM
I was wondering of those of you that mounted an amp under the driver's seat on a 7th gen accord:
--Did you screw into the floor, or place some wood under the carpet to screw into?
--Did you ground to the seat bolt, or is there something better under the carpet?
I know mine will fit there, I just want to have my bases covered when I pull the whole car apart...I hate surprises!!! posted_image
Thanks,Jeremy
Posted By: saxdogg
Date Posted: August 06, 2006 at 1:46 PM
Thanks for your reply...yeah that's why I'm asking...if anyone had screwed into the floor there and if it was clear! I assume looking from underneath the car doesn't always tell the tale!
I was thinking if I had to use a seat bolt, I'd put it under the seat mount and scratch away the paint from the floor...decent?
Thanks nouse...
Posted By: DYohn
Date Posted: August 06, 2006 at 2:47 PM
Another option to consider is using heavy-duty adhesive Velcro.  Stick the "hook" side to the bottom of the amp and it will stay securely positioned on most automotive carpet.  Keeps the amp from sliding around.  Available at most hardware stores.
Posted By: saxdogg
Date Posted: August 06, 2006 at 3:01 PM
oooooo....good tip...I may try this, DYohn
