Dual Amp Setup
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81275
Printed Date: April 01, 2026 at 11:53 AM
Topic: Dual Amp Setup
Posted By: rboutin2
Subject: Dual Amp Setup
Date Posted: August 06, 2006 at 3:42 PM
I've got two rockford amps, both pushing 2 15" treo ssi 4 0hm dvc subs. I want to upgrade to get full power to my subs, but I am not sure if I should go with a dual or single amp setup. I like the look of dual amp, and if one of my subs goes, the impedance won't change and ruin the other sub, but a single amp setup is cheaper, and pushes both subs exactly the same. I am having a problem with my dual amp setup now in that one subs is hitting slightly harder than the other (the output voltage is about 1 volt ac higher), cuz the amps are slightly different. (same model, i think one's a little newer). If i get two amps exactly the same, brand new, is it possible i might still have the same prob, and is there a way to fix it?
Posted By: stevdart
Date Posted: August 06, 2006 at 10:00 PM
You can adjust the output of the amp so that they both are the same output voltage.  Just the lightest touch on the gain will make a 1 volt difference...if you can get it that close, even.  When you're at ~28 volts and higher, 1 volt isn't that much difference to worry about.
Posted By: rboutin2
Date Posted: August 07, 2006 at 10:11 AM
I think i finally found some good amps, for a decent price on ebay. An Orion HCCA-D2400. They push 800 rms into 2 ohms, and people have told me they are good amps. Did I find the right one this time?
Disturbin' Tha Peace
Posted By: smokinsmitty
Date Posted: August 07, 2006 at 8:39 PM
Yes, Orion is great quality! nice choice on subwoofers also.
1 15" Memphis Mojo,
Memphis 16-mc1000D amp,
Audiopipe 4gauge mp kit, Pioneer DEH4700MP head unit.
2002 Yamaha 660R Raptor
Yamaha FZR600 crotch rocket
Sea Doo XP800
Sea Doo Spi
Posted By: killer sonata
Date Posted: August 07, 2006 at 9:03 PM
I dont think anyone can say with huge certainty that they found good amps on ebay. You never know what you are buying until you get it on that place. Ebay is full of scams.
