problem with my amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81290
Printed Date: May 16, 2026 at 1:32 AM
Topic: problem with my amp
Posted By: segovia34
Subject: problem with my amp
Date Posted: August 06, 2006 at 10:06 PM
I recently installed and amplifier Planet audio amp PC225HC, and one Kicker L7 Dual two ohm.
I installed it in my 2004 BMW 525i, I used an audiocontrol LC8 to get inputs for the amp.
I have the woofer wired at 1 ohm.
The problem im having is the amp gets hot and goes into protection.  I know im not exceeding the ohm load because my amp is good to .5ohm.  Can anyone help me on what my problem might be?
Posted By: stevdart
Date Posted: August 06, 2006 at 10:39 PM
https://www.google.com/search?sourceid=navclient&ie=UTF-8&rls=GGLG,GGLG:2005-35,GGLG:en&q=Planet+Audio+PC225HC+amplifier
Posted By: killer sonata
Date Posted: August 06, 2006 at 10:51 PM
sounds like the amp cant handle 1ohm and is going into protection mode so you dont completely kill it.
"People with mullets live 40% longer"   - Ricky Bobby
Date Posted: August 06, 2006 at 10:53 PM
according to the planet audio website, that amp doesnt even exist
Date Posted: August 08, 2006 at 10:11 PM
Planet Audio P225HC
Planet Audio High Current Two-Channel Power Amplifier, Bridged Power into 4 Ohm is 50 Watts X 1, RMS Power into 4 Ohm is 25 Watts X 2 at 0.01% T.H.D., Signal-To-Noise Ratio is 103 dB, Frequency Response is 10 Hz to 100k Hz, Tri-Mode Operation, Built-In Continuously Variable Low and High Pass Crossover, Continuously Variable Bass Boost (+18 dB), Line Output with Independent continuous Variable High/Low Pass Crossover, Gold Plated conenectors, Dimensions: 22-3/4" (L) X 2-1/2" (H) X 9" (W). Handcrafed in USA.
Specifications
Mosfet Power Supply: Yes
Built In Cross: Yes
Bass Boost Circuit: Yes
Bridgeable: Yes
RCA Input: Yes
Speaker Input: Yes
Overload Protection: Yes
Thermal Shut off: Yes
Channels: 2
Crossover Type: HP / LP
SNratio: 104 dBA
THD Noise: 0.01%
Dimensions: 9"w x 2 1/2"h x 22 3/4"
 RMS Power: 25 watts x 2
Min. Load: .25 ohm
25x2 - 4 Ohm
50x2 - 2 Ohm
100x2 - 1 Ohm
200x2 - 1/2 Ohm
400x2 - 1/4 Ohm
50x1 - 4 Ohm Bridged
100x1 - 2 Ohm Bridged
200x1 - 1 Ohm Bridged
400x1 - 1/2 Ohm Bridged
Posted By: Flakman
Date Posted: August 08, 2006 at 10:24 PM
segovia: Even if the amp is rated to run that low, that doesn't mean it can handle the heat. Running at lower impedence means that the amp will be losing more and more power to heat. The only possible help would be if you have the amp mounted upside down or don't have enough room around it to allow for air circulation it needs. If something like that isn't the case, you're amp can't take the heat of 1 ohm operation.
...and then there's what killer said. Can't see anything like that at Planet Audio.
The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
Date Posted: August 10, 2006 at 6:39 PM
amp was made like awhile back when planet audio and zed audio where together.
Posted By: KarTuneMan
Date Posted: August 11, 2006 at 1:55 AM
....is the amp getting enough current to make the power your asking it too? What the charging/battery situation like on this car? AND, I don't think it as a Planet amp either.... How old is this thing???
