Need more power
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81415
Printed Date: April 01, 2026 at 7:26 PM
Topic: Need more power
Posted By: Markland556
Subject: Need more power
Date Posted: August 09, 2006 at 9:13 PM
Ok, well i have an 86' Mercedes 300E. It has a wussy 60 amp alternator. I have a JL 100/1 with an MTX 9500. I killed my optima yellowtop already but i dont know if thats what killed it. All i know is that my alternator was running at max when the battery was dead but that doesnt say much about the stereo.
Im just wondering what i can do to avoid upgrading my alternator. Can i run 2 batteries or something to help this system out. I had it running fine for a day but i had problems with the fuses.
I will be doing some amp testing tomarrow, but i just want to find out what i can do to keep the system alive. Maby 2 batteries??
Posted By: KarTuneMan
Date Posted: August 09, 2006 at 9:40 PM
2 batteries won't help a bit....if you can't keep them charged. (new HO alternator)
Posted By: gavin9797
Date Posted: August 09, 2006 at 10:06 PM
My best guess is @ 60amps, your alternator is probably close to its limits for the OEM spec. As is always suggested on here when it comes to power problems, you will need to upgrade the Big 3. How to upgrade the Big Three, From there As KarTuneMan said, you will need to upgrade your alternator. I believe any other way would just be a band-aid solution, and you will continuesley be fighting this problem.
