2 dvc subs down to 2 ohm?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81436
Printed Date: May 16, 2026 at 8:48 AM
Topic: 2 dvc subs down to 2 ohm?
Posted By: kew85204
Subject: 2 dvc subs down to 2 ohm?
Date Posted: August 10, 2006 at 10:33 AM
is there any way i could get 2 dvc subs to go down to 2ohm load. both of the voice coils are at 4ohm. and my amplifer goes down to 2ohm. and its a mono amplifer. i have looked all over and im not sure if its possible. plize help me guys
Posted By: haemphyst
Date Posted: August 10, 2006 at 10:38 AM
You cant... 1, 4 or 16 ohms are your only choices. Wrong woofer choice, or wrong amplifier choice...
If you only ran one coil per woofer, you could get a 2 ohm load, but be mindful of your reduced power handling. Allow 25% less power capability.
------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
Posted By: kew85204
Date Posted: August 10, 2006 at 11:17 AM
oo ok so you guys are sure right so my woofer is a piooner 1000 watt max so it would be ok if i sended 400 wats rms into each subwoofer and it wont hurt it??? and thankyou for helping me out
Posted By: kew85204
Date Posted: August 10, 2006 at 11:43 AM
ok kool thankyou soo much for your help now i dont have to hurt my head from thinking so much.
Date Posted: August 10, 2006 at 11:47 AM
I personally don't see any problem with it. As long as your woofers are rated 500 watts each, 400 should be safe, thermally speaking.
Posted By: forbidden
What is the mono amp?
------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: kew85204
Date Posted: August 10, 2006 at 12:14 PM
its a Audiobahn A8000t
Posted By: kew85204
Date Posted: August 10, 2006 at 12:16 PM
and haemphyst you said it would be safe thermaly speaking. so what elts is there to worry about
