Need a good one ohm stable amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81574
Printed Date: April 01, 2026 at 10:42 PM
Topic: Need a good one ohm stable amp
Posted By: dubzino
Subject: Need a good one ohm stable amp
Date Posted: August 13, 2006 at 4:24 PM
Ok I currently run two alpine 10 type r's on a a kenwood 600 that I have running at two ohm stereo. Sounds good but these subs are thirsting for more power. SO I am thinking the audiobahn a8002t or a8002v to run 400 rms per sub or a lanzar opti1400d amplifier. Please help me out guys. I am really having trouble deciding.
Posted By: haemphyst
Date Posted: August 13, 2006 at 4:32 PM
Well, the Audiobahn (or the new Lanzar, too) is NOT where you want to go for a "good one ohm stable amp". End of story. Good and Audiobahn are contradictions in terms, and shouldn't even be uttered in the same sentence together.
A better suggestion would be a stereo amp that is rated for the RMS power of your woofers, at their impedance. You are saying 2 ohms, and at 2 ohms any respectable amp rated 500 watts per channel would do FAR better than ANYTHING from Audiobomb. Keep the impedance up, your amp will run cooler, and last longer, the distortion will be lower, damping will be higher.
BUT, if you insist on running at 1 ohm, look at Memphis (at 550 watts per woofer). Decent amplifiers, and from what I know, prices are OK, too. Another option for the 2 ohm load would be Zapco (at 360 watts per woofer). The DC750.2 More expensive, but also more worth it... Both of these products are VERY conservatively rated pieces of gear. Look also toward Eclipse. Wire one voice coil to each channel of that baby, and you'd SWEAR you had all the power you were looking for in the AB. Super clean, super cool, and also conservatively rated.
ANY of those amps will spank Audioburn, in both reliability and sound quality. The 'bahn stuff are really just flame sportin', chrome plated turds.
Posted By: killer sonata
Date Posted: August 13, 2006 at 5:37 PM
I mostly agree with haemphyst except for the part about getting a class A/B amp. There are some multi channel amps out now with whats called ICEpower class D. Eclipse and alpine are the only ones that I know of so far who are doing this. The technology is amazing. Somehow they made a class D amp sound just as good as A/Bs. The bonus is the efficiency is better than a normal class D.
Date Posted: August 13, 2006 at 10:46 PM
I think you were thinking AB meant A/B class amplifier... Nope. That's AudioBahn... Sorry. The Zapco was the only Class AB amplifier in the group, and I'd have ANY zapco, pretty much any day, over pretty much ANY other amplifier. Sure, for a subwoofer, he might not NEED that quality of amplifier, I was just tossing it out there, though. posted_image (The notable exception to this would be, in fact, the old school Nakamichi amplifiers...)
Posted By: Velocity Motors
Date Posted: August 13, 2006 at 11:18 PM
For decent raw power you can look towards the MTX TA7801 which is 1 ohm stable and can put out about 1500 watts as well. Just my 2c's
Posted By: forbidden
Date Posted: August 13, 2006 at 11:21 PM
Concept also makes a great 1 ohm stable amp. The CCD1210 might interest you.
Posted By: aznboi3644
Date Posted: August 14, 2006 at 2:19 AM
My vote is for the Memphis 1000D...only because I've had experience with this amp...reliable and still runs cool at 1 ohm...I mean after an hour of hard playing you can still hold your hand on the amp and it feels warm
Posted By: dubzino
Date Posted: August 14, 2006 at 12:30 PM
Thanks for all the input guys. But I didnt want to go AB class really cause I here its harded on the electrical system. But some people ar etelling me Lanzar optidrive series is good. I was looking at the 1400d. Anyon eever heard or know anyone running this amplifier. Its supposed to do 1000rms at 1 ohm.
Date Posted: August 14, 2006 at 1:05 PM
Operative phrase here: SUPPOSED TO DO! It won't.
I told you already, my personal opinion would be NO LANZAR. The new stuff is on a par with the Audiobahn stuff - all flash, and no fire. A few years back, it was decent stuff, but never great.
In the amps I recommended above, the only Class A/B amp was the Zapco, the others ARE Class D.
If you think that a Class D, at 1000 watts is going to be THAT much easier on your electrical system you are sadly mistaken. A 1000 watt Class A/B will pull about 20 more amps than would a Class D amp of equivalent output power. At 1000 watts, even a Class D amp is going to require a high output alternator, you have no choice in the matter.
Don't get hung up on the amplifier class, by the time you get to those output levels, it wont matter...
Date Posted: August 14, 2006 at 3:12 PM
Say no to Lanzar in case you would like a second professional opinion.
Date Posted: August 15, 2006 at 1:09 AM
If you want the Lanzar than sure go ahead and buy a huge paperweight
Posted By: dubzino
Date Posted: August 16, 2006 at 7:18 PM
Ok I finally gave in and went with the hifonics BX1205D. Is there any difference in the 05 model and 06? Anyways it says it makes 1200rms at 1ohm but most bench tests say that it goes a little over 1000 rms with most stock electrical systems so. I have a stock electrical system in my 2001 infiniti i30 so I do not want to change the alternator because of warranty issues. B ut I have seen nothing but good reviews for this amp. Give me some input guys!
Date Posted: August 16, 2006 at 9:08 PM
OK, you never listed HiFonics as an option, but NO, that's not much better than the Audiobahn or the Lanzar...
Had you mentioned that one in the first place as one of the amps you were considering, I'm sure you would have heard MORE responses like this.
You asked, you didn't list all the amps you were considering, you got a list of VERY reliable, and very honestly rated amplifiers, and then you still went with some other crappy amp, the one you never listed... Enjoy. ...and best of luck with that...
Oh, and by the way? You are GOING TO HAVE TO CHANGE THE ALTERNATOR! You will not have much choice with 1000 watts. That is at least 120A more than your stock system was ever designed to sustain. Warranty? If you put that in, and blow your stock alternator and ECU, your warranty will be null and void from the get-go. Again, best of luck with that.
Posted By: dubzino
Date Posted: August 17, 2006 at 9:30 AM
Well we shall see. I had an audiobahn a2150hc which is 1200 rms at one ohm and two 12" audiobahn subs of 700 watt rms each. Never had a problem with my stock alternator or anything. And I only had a capacitor in there that waws 5 farads.
